LG 47LW5700 picture calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-14-2012, 11:58 PM - Thread Starter
babbulu99's Avatar
I have just bought LG 47LW5700 LED TV and not really satisfied with the standard color and picture settings.
Is there's any recommended settings that can satisfies while watching the programmes.
babbulu99 is offline
post #2 of 11 Old 04-15-2012, 06:10 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
You can buy a consumer calibration disk or download the free AVS 709 disk from this site to properly set the main user controls. You can also hire a pro to fully calibrate the set for you. You can spend many hours learning how to perform a full calibration and invest 2x what a pro would charge in software entry level hardware so you can do it all yourself.
But using other peoples settings is not going to do anything for you.. consumer level hardware is not accurate enough to be the same from set to set.
Check the forum for you display type and look for the thread dedicated to your set, you will find lots of numbers posted.. once you try 2 or 3 different set of number you will understand what I mean.
Where in the country are you located, there are DIY Enthusiast like myself that have invested the money and may be willing to do a full calibration just for the experience.
Looks like this is your first post.. spend some time and do some reading.
Sharing display menu settings?
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 11 Old 04-20-2012, 03:54 AM - Thread Starter
babbulu99's Avatar
Hi
Thanks.But I need more specific configuration for my led tv such as below:
Backlight:
Contrast
Brightness
Sharpness
Color
Tint
Color temp
and so on
post #4 of 11 Old 04-20-2012, 04:13 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Originally Posted by babbulu99 View Post
Hi
Backlight:
Contrast
Brightness
Sharpness
Color
Tint
Color temp
and so on
Doug
post #5 of 11 Old 05-06-2012, 11:53 AM
densin's Avatar
@ babbulu99, Why not just go into your tv set-up. Then your picture setting set-up and use the Picture Wizard.
densin is offline
post #6 of 11 Old 05-09-2012, 12:15 AM - Thread Starter
babbulu99's Avatar
Of course I want to use the picture wizard but I need the actual range of settings for pic wizard.
post #7 of 11 Old 05-09-2012, 09:52 AM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1043
Airscapes said it best. Get one of the cal disks (like the free AVS-HD709) and set the basic settings yourself (contrast, brightness, sharpness, aspect, color,etc). That can go a long way in improving your pq without getting into a full calibration which requires the use of meters and special software. Every tv that comes off of the production line is going to be different due to spec ranges so "sharing" settings doesn't always work. Besides, the environmental conditions are different for everyone (lighting, use of a bias light, etc) and there is personal preference that comes into play as well.
Otto Pylot is offline
post #8 of 11 Old 05-10-2012, 11:10 PM - Thread Starter
babbulu99's Avatar
Where to find the cal disks (like the free AVS-HD709)
post #9 of 11 Old 05-11-2012, 04:47 AM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
http://www.avsforum.com/avs-vb/showthread.php?t=948496
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #10 of 11 Old 06-13-2012, 10:54 AM
georgetoo's Avatar
I found picture wizard on initial setup on my LG47LW5700 but cannot find the Picture wizard again. Frankly I prefer the old style menus but could use some help in accessing Set Up and or Picture Wizard......tia
georgetoo is offline
post #11 of 11 Old 06-13-2012, 12:31 PM
PlasmaPZ80U's Avatar
Quoted: 2317 Post(s)
Liked: 716
on my 2011 LK450 the picture wizard can be found under the picture menu and is meant for the ISF Expert 1 pic mode
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
Reply Display Calibration
