gradient banding question? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-15-2012, 10:40 PM - Thread Starter
ziggurcat's Avatar
i apologize if this has been done to death (or if this is posted in the wrong forum), but i just had a small question on gradient banding.
i own an LG 50PV400 - and it's a really great TV - but i wanted to find out if there's a way to "eliminate" gradient banding? is it a matter of lowering the contrast/sharpness or would adjusting the IRE settings eliminate that (which i can't really do since i don't have the proper calibration tools to adjust those settings)?
i mean, how i have it set there's very little banding, but every once in a while i will notice some slight banding in the gradients. it doesn't necessarily bother me, but if there's something i can do to tweak the set a bit more to decrease the banding and improve the image quality, i'd be a happy camper.
thanks in advance for any of your suggestions.
ziggurcat is offline
post #2 of 8 Old 04-16-2012, 06:18 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
How did you come by your settings and are all the CMS color/tint settings set to 0?
I have the LK and if you attempt to adjust CMS settings you end up wit color banding.. at least I did..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 8 Old 04-16-2012, 07:48 AM
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
What sort of content are you getting banding on? Is it just on stuff like digital cable, where they could be overly compressing it to cause the banding, or on well done Blu-ray transfers as well? is it on any color gradient, or just certain colors? Is it only light gradients, or dark ones as well?
Really there are a lot of things that could cause this. It could be the source content has a lower bitrate and the gradient is showing up. It could be that an adjustment in the CMS (to colors, or gamma or grayscale) are causing the banding by not having enough bit depth to work with to do adjustments without these kind of issues. More information about when these issues are appearing would help to narrow this down.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
post #4 of 8 Old 04-16-2012, 10:45 AM
kyokushinkai's Avatar
A question.
10-bit dithering applied from a radiance mini 3D can help reduce the banding of plasma low bit depth for color reproduction?
Or is something inside of the plasma display bit depth and color to create?
Excuse my English
Thank you very much
kyokushinkai is offline
post #5 of 8 Old 04-16-2012, 06:35 PM - Thread Starter
ziggurcat's Avatar
i used the AVS rec. 709 disc. i have only adjusted the basic settings (brightness, contrast, sharpness). i have made minor adjustments to colour and tint, but i have not touched the CMS or IRE settings (they're all zeroed).
post #6 of 8 Old 04-16-2012, 06:42 PM - Thread Starter
ziggurcat's Avatar
i've noticed while watching TV (digital cable), in the PS3 XMB and in the X360 guide. it doesn't seem to matter what colour, light or dark gradients.
i have not made any adjustments to the CMS or IRE settings. the gamma setting is set to the default "medium".
post #7 of 8 Old 04-16-2012, 07:53 PM
PlasmaPZ80U's Avatar
Quoted: 1960 Post(s)
Liked: 559
possibly not a calibration issue, try cinema or expert mode at defaults to check
also, do you see this issue on a BD movie?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #8 of 8 Old 04-16-2012, 09:50 PM - Thread Starter
ziggurcat's Avatar
well, it's actually worse at the defaults.
i want to stress again that it's not exactly terrible banding to begin with - it's mostly really subtle - i was just hoping to be able to tweak the TV a little to lessen it a little further. i have a feeling, though, that i'd need to properly set the IRE and CMS to gain any improvements.
Reply Display Calibration
