Massive Color Drift Correction for i1 Display Colorimeter - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 95 Old 10-11-2012, 03:12 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Originally Posted by PlasmaPZ80U View Post
What does SpectraCal do when you send in the i1Pro to them?
We can only re-certify them.
If you need an i1 Pro recalibrated, then need to get sent to switzerland.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #92 of 95 Old 10-11-2012, 03:19 PM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
So, if someone sends in a i1pro for re-cert to SpectraCal and it is out of spec (unlikely but let's assume it is), do they still get charged $175 for the re-cert? I ask because I assume the re-cert would then be pointless if the meter was out of spec and the owner would have to spend another several hundred dollars for the re-cal in Switzerland.
Also, do you update the LED tables during a re-cert (assuming the meter is in spec)?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #93 of 95 Old 10-11-2012, 03:23 PM
Liked: 559
Also, how does the meter verification service you offer differ from the re-cert? It's a whole lot cheaper ($50).
post #94 of 95 Old 10-11-2012, 03:53 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
Thank you Joel for sharing this. I think a lot of folks who are new to the DIY aspect of calibrating don't have a clear understanding of the differences between certification and calibration, and what they mean quality-wise and cost-wise. Good questions PlasmaPZ80U!
Otto Pylot is online now
post #95 of 95 Old 10-11-2012, 04:21 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
The verification service is only for certain meters and is basically only a pass fail test.
For the i1 Pro the only service available would be the Recertification service. That would include getting the enhanced LED table added or updated as well.
Joel Barsotti
SpectraCal
sotti is offline
Reply Display Calibration
