LC-60LE831U sharpe Calibration Newbie - AVS Forum | Home Theater Discussions And Reviews
Old 04-19-2012, 11:00 AM - Thread Starter
jameslyle's Avatar
Hi Guys, I recently purchased a LC-60LE831U sharpe. I picture looks a little weird, I was wondering if anyone could help me find some calibration settings for it? Thanks a ton!
jameslyle is offline
Old 04-19-2012, 11:50 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
There are many professional Calibrators on this forum that you can make an appointment with and they will come to your place and calibrate the display using highly accurate equipment and software.
If you are looking for someone to provide you setting numbers, check out the thread in the flat panel forum for your set model number.
This forum is about calibration and sharing numbers is not calibration, this thread will explain why sharing settings does not work very well.
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
