GCD - Gamut Calibration Disk - Page 10 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What format would you prefer for the HTPC?
.mp4 31 31.31%
.mkv 67 67.68%
others (please detail in thread) 1 1.01%
Voters: 99. You may not vote on this poll
 3Likes
post #271 of 633 Old 06-23-2012, 02:47 AM - Thread Starter
visca blaugrana's Avatar
Sorry in the delay in getting the Blu ray version online, but please find in the first post
Additional I had an idea:
I was thinking of adding the required scenes from here and then on the pop-up menu put the text from the article. any comments on doing that?
additional, is there any preferences on the pop-up navigation, would it be interesting to add some links to different sections in strategic right positions?
EDIT:
First post updated with a Blu-Ray Version and a AVCHD Strict. if the normal AVCHD version dont work, try the strict version, however please also let me know.
visca blaugrana is offline
post #272 of 633 Old 06-23-2012, 05:45 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
The disk I downloaded last week GCD_4.3.4.zip seems to work fine on my Samsung BRP BDC6800.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #273 of 633 Old 06-23-2012, 09:37 AM
djams's Avatar
That's a great idea - but are there copyright concerns? I'd hate to see you get into trouble.
BTW - thanks for all your hard work on this. (You too, zoyd)
djams is offline
post #274 of 633 Old 06-23-2012, 09:54 AM - Thread Starter
not sure about copyright, but looking here it looks like he had some problems selling the disk, but there dont seam to be any problems aslong as people burn there own copy. Not really sure about it though
post #275 of 633 Old 07-01-2012, 03:14 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
visca blaugrana
Please add patterns 10% windows with fixed 22% APL to plasmas.
(Zoyd-Given this data set, for plasma calibration I would opt for 10% by area windows on a multilevel fixed background designed to yield 22% constant APL).
Pattern Calculator (2).xlsx 8k .xlsx file
Why Color Test Patterns contains 12 patches?
EBU (Tech 3325 ) contains The test inputs for colour gamut are test patterns 5-red, 5-green and 5-blue.
A set of 15 EBU test colours was defined in EBU Tech 3237 and its supplement [13], based on
certain Munsell chips, and these are also a useful set of test colours for characterising a display.
Whilst these test colours were originally intended as camera input test colours, here we use these
colours referred to the output of the display.
For the measurement of the EBU test colours (based on sample data given in EBU Tech 3237 and its
supplement [13], and assuming a display gamma of 2.35) the field patches should be set to the
digital 10-bit values given in the table below.
10-bit code values at monitor
input
Expected monitor output
Sample Description D'
Y D' CB D' CR Y (%) u' v'
EBU 1 Dark Skin 381 470 578 9.6 0.2530 0.5015
EBU 2 Light Skin 636 457 599 37.7 0.2366 0.4931
EBU 3 Light Greyish Red 582 478 592 29.8 0.2364 0.4848
EBU 4 Light Yellow Green 577 340 480 29.9 0.1807 0.5452
EBU 5 Light Bluish Green 579 544 411 29.8 0.1629 0.4552
EBU 6 Light Violet 586 597 543 30.1 0.2087 0.4157
EBU 7 Foliage 433 443 487 13.4 0.1813 0.5207
EBU 8 Medium Red 460 465 703 19.4 0.3248 0.4974
EBU 9 Medium Green 658 380 370 43.6 0.1505 0.5329
EBU 10 Medium Blue 470 639 468 17.2 0.1791 0.3706
EBU 11 Dark Red 319 490 616 6.5 0.3046 0.4895
EBU 12 Dark Green 487 422 396 19.9 0.1462 0.5321
EBU 13 Dark Blue 321 617 491 6.0 0.1825 0.3422
EBU 14 Medium Yellow Red 655 349 673 43.5 0.2726 0.5273
EBU 15 Medium Purple 494 601 593 20.0 0.2349 0.4034
Table 8: EBU test colour values.
ebutech3325.pdf 1665k .pdf file
I have already made patterns.
22APL.zip 140k .zip file
anta1974 is offline
post #276 of 633 Old 07-01-2012, 10:26 AM - Thread Starter
I am at the moment encoding videos with 10%APL patterns
I will not be including the 15EBU patterns as zoyd and my self agreed on the more widely used patterns that are already included.
I will not give a ETA for the new beta version, simply because i am busy at work and with the family, however I can guarantee that when I have a bit of time I am working on it.
is there any additional comments on the navigation via pop-up or is that fine?
post #277 of 633 Old 07-01-2012, 12:18 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
1) 10% area and 22%APL?
2) Is not better than 15 patterns of 12?
3) ok
4) no
anta1974 is offline
post #278 of 633 Old 07-01-2012, 03:53 PM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
1. Yes
2. No added value. The 12 Munsell color checker overlap with the EBU colors plus RGBYCM is more than adequate to evaluate a consumer display.
zoyd is offline
post #279 of 633 Old 07-02-2012, 09:22 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Thank you very match.
I've made for yourself the patterns 10%area and 22%APL
http://zalil.ru/33527279
http://zalil.ru/33530436
can try
anta1974 is offline
post #280 of 633 Old 07-02-2012, 10:40 AM - Thread Starter
I got patterns (video streams) and menu files ready, but need to re-author the disk.
Is there really no comments on the popup menus or are they useless in its current form?
post #281 of 633 Old 07-02-2012, 08:36 PM
takeokun's Avatar
For me they are fine and handy.
I use them as a shortcut to change patterns. (e.g., from 100% to 10%) smile.gif
takeokun is offline
post #282 of 633 Old 07-03-2012, 09:51 AM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #283 of 633 Old 07-03-2012, 10:19 AM - Thread Starter
so I can leave them as they are for now?
post #284 of 633 Old 07-03-2012, 11:55 AM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #285 of 633 Old 07-03-2012, 11:59 AM - Thread Starter
The problem with that it's more or less impossible in adobe encore.
For now is it necessary with popup menu on colour check patterns? - it will be included later
post #286 of 633 Old 07-03-2012, 12:31 PM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #287 of 633 Old 07-08-2012, 11:18 AM - Thread Starter
sorry for the delay guys but please see first post for the latest version containing 10% windows with fixed 22% APL.
any comments or bug reports please let me know.
post #288 of 633 Old 07-08-2012, 12:58 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Great news!
anta1974 is offline
post #289 of 633 Old 07-08-2012, 01:35 PM
PlasmaPZ80U's Avatar
Quoted: 1966 Post(s)
Liked: 560
does this disk have any full field patterns for LCDs?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #290 of 633 Old 07-08-2012, 01:38 PM - Thread Starter
Not yet its one of the things that will be included
post #291 of 633 Old 07-08-2012, 01:48 PM
Liked: 560
If I just want to burn a copy of this disc once, how long should I wait for the final release?
post #292 of 633 Old 07-08-2012, 03:14 PM
rahzel's Avatar
Liked: 148
How's the mp4 version progressing? Is it still being worked on?
Thanks for all your effort in this and to all of those involved.
rahzel is offline
post #293 of 633 Old 07-08-2012, 03:49 PM - Thread Starter
Regarding a date for the final release I don't think that would be possible, due to plans changes all the time, and also it's very time consuming, but I can say for sure it's not gonna be within the next month, also I would like to encourage you to try it out and come with your feedback, it would be much appreciated.
Regarding the mp4 version I don't have any plans to do it until there is a complete list of patterns.
Is the mp4 version just the patterns as mp4 in a folder structure that follow the menu system on the disk?
Sent from my iPad using Tapatalk HD
post #294 of 633 Old 07-08-2012, 03:55 PM
rahzel's Avatar
Liked: 148
Ya, similar to the AVSHD709 disc... it just has all of the individual patterns in mp4 format separated with folders. When I calibrate my HTPC, I like to just play the patterns as mp4 video files. I use MPC HC and it doesn't seem play the AVCHD disc properly. I've also tried VLC. Plays fine in my PS3 though.
rahzel is offline
post #295 of 633 Old 07-08-2012, 09:34 PM
Chad B's Avatar
Quoted: 495 Post(s)
Liked: 1190
Any chance of getting these patterns as .bmp images? If so, I could load them into my pattern generator.
Chad B is offline
post #296 of 633 Old 07-09-2012, 12:46 AM - Thread Starter
If I can find a batch converter from .tga to.bmp then no problem.
There is a problem with the 10% apl munsill test patterns. Will update as soon I get a chance
Chad B likes this.
post #297 of 633 Old 07-09-2012, 10:24 AM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #298 of 633 Old 07-09-2012, 01:24 PM
hungro's Avatar
Quoted: 164 Post(s)
Liked: 111
I sent visca a pm. Links not working for me either . It acutally doesn't show that there is a link with my version of fire fox .
hungro is offline
post #299 of 633 Old 07-09-2012, 01:37 PM - Thread Starter
Hmm I wonder what have gone wrong, I am just making a version where the 10% window apl Munsill patterns are fixed this should be up tomorrow
post #300 of 633 Old 07-09-2012, 02:49 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Very well
anta1974 is offline
Reply Display Calibration
