GCD - Gamut Calibration Disk - Page 13 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What format would you prefer for the HTPC?
.mp4 32 31.68%
.mkv 68 67.33%
others (please detail in thread) 1 0.99%
Voters: 101. You may not vote on this poll
 3Likes
post #361 of 633 Old 07-29-2012, 12:24 AM - Thread Starter
visca blaugrana's Avatar
What player are you using?
I would not have thought it would solve the problem.
Regarding the differences between the 2 disks. The normal version is a blu ray version patched to work as a avchd disk, where the strict version is completely re-authored for avchd
visca blaugrana is offline
post #362 of 633 Old 07-29-2012, 11:42 AM
PlasmaPZ80U's Avatar
Quoted: 2318 Post(s)
Liked: 716
I have the slim PS3. To be fair, the pop-up menus never worked for me on the AVS disc either, so the issue is likely the PS3. (It doesn't seem to support pop-ups menus when the AVCHD format is used.)
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #363 of 633 Old 07-29-2012, 12:17 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
zoyd is offline
post #364 of 633 Old 07-29-2012, 01:50 PM
Liked: 716
Originally Posted by zoyd View Post
My PS3 BT remote works fine using the square to bring up the pop-up menus.
did you burn the AVCHD version or the BD version? I'm having the issue with the AVCHD version (burned to a DVD-R).
EDIT: the square button does bring up the pop-menu, at least with most pattern types. The pop-up button doesn't work.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #365 of 633 Old 07-31-2012, 05:13 AM
vincentfam's Avatar
Liked: 24
Update on samsung blu ray bd-p1600
The download of the gcd worked! I changed "download software" for the avchd dvd version. Thank you for your assistance.
Vincentfam
vincentfam is offline
post #366 of 633 Old 07-31-2012, 12:01 PM - Thread Starter
good to hear it worked, did you use the avchd strict version?
post #367 of 633 Old 07-31-2012, 12:43 PM - Thread Starter
I was considering the following patterns:
Contrast clip pattern (White) - Similar to AVSHD 709 disk
Brightness clip pattern (Black) - Similar to AVSHD 709 disk
Brightness clip pattern (All Colors) - Similar to contrast clip pattern on GCD
Meter Position pattern
ramp (16-235) for Red
ramp (16-235) for Green
ramp (16-235) for Blue
ramp (16-235) for Cyan
ramp (16-235) for Yellow
ramp (16-235) for Magenta
ramp (16-235) for White
any others??
post #368 of 633 Old 07-31-2012, 01:00 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
For the ramps, you might consider 0-255 with marks at 16 and 235.
rmongiovi is offline
post #369 of 633 Old 07-31-2012, 03:11 PM
vincentfam's Avatar
Liked: 24
I used the regular version and not the strict one. Apparently, one of my old download software wasn't working properly and thought that I would try a different one, and I am glad I did.
Thanks again for your assistance. It is really appreciated.
Vincentfam
post #370 of 633 Old 07-31-2012, 05:56 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
any others??
The ramps should go to 255.
Since they are encoded as YCC and the legal values are 16-235 for Y and 16-240 for Cr and Cb, there are alot of legal values that are above 235.
See Don Munsil's post, one of the creators of spears and munsil discs
http://www.avsforum.com/t/1378084/disney-wow-calibration-and-clipping#post_22217360
sotti is offline
post #371 of 633 Old 07-31-2012, 06:40 PM
Liked: 716
what are these ramps for?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #372 of 633 Old 07-31-2012, 06:42 PM
Liked: 716
any others??
I would certainly like to see a meter position pattern. I'm not sure what use a brightness clip pattern that showed all six colors would have, though. I think a black pattern for that would be plenty.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #373 of 633 Old 08-01-2012, 07:05 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
15 EBU test colours was defined in EBU Tech 3237 and meter position pattern
anta1974 is offline
post #374 of 633 Old 08-10-2012, 06:00 AM
Koperfild's Avatar
Hello Gentelmans
I've read all 13 pages of discussion and dozens of other pages, tutorials and color management books hovewer I still can't get one thing. If you could spend some time on explaining this I would be grateful.
The Gamut Calibration Patterns are designed for 2.22 gamma. Let's assume that production studios use the same gamma formula. So, to achieve proper saturation levels we need to take gamma-weighted R'G'B' triplet. Therefore calibrating a display to different gamma will induce a saturation shift and the shift must be corrected.
But why do we change targets like in the spreadsheet attached to the first post? Isn't the triplet calculated for gamma 2.22 supposed to produce the same saturation on a display of gamma let's say 2.4 ? Why would we increase targets' saturation when increasing gamma? I thought we have to increase display's saturation to compensate the change on it...
In an example: the dark skin target on 2.22 flat gamma is (xyY) 0.401 0.359 10.01%. But if i change the gamma to 2.6 it becomes 0.418 0.362 6.84%. Why? Why are dark skin tones in a movie supposed to look more saturated on a 2.6 gamma display? Shouldn't they be just darker?
Koperfild is offline
post #375 of 633 Old 08-10-2012, 03:36 PM
zoyd's Avatar
Liked: 1064
zoyd is offline
post #376 of 633 Old 08-11-2012, 03:36 PM
Koperfild's Avatar
Zoyd sorry it's not that unusual for me, consider the follwing examples please:
I took a photo that was colour corrected on a 2.2 gamma monitor. Then lowered the gamma of the image to ~1.8. The saturation dropped significantly.
Below the photo there is a target from your spreedshet for gamma 1.8. The points lie closer to the white point than in original target. Why we aim for lowered saturation? The picture is already washed out of colours.
And the opposite example with increased gamma of the image (to ~2.5). The image looks oversaturated and the targets for lie farther from the white point. So basically everything is fine?
So the image should look oversaturated when increased gamma and undersaturated when decreased?
Shouldn't we compensate for saturation when changing gamma?
post #377 of 633 Old 08-12-2012, 08:08 AM
zoyd's Avatar
Liked: 1064
I don't get your point, when doing the R'G'B' to xyY transform the value of gamma affects both luminance and saturation (except at 100%) as you have seen from your photographs. So the EOTF you calibrate to will change both. Since historically there is no standard EOTF there is also no firm saturation target so you must choose one based on your viewing environment, display capabilities and the principles of color science. There is nothing standard about 2.2 gamma in the film industry, your source material might have been color corrected on a monitor with 2.35, or 2.4 or a variable gamma monitor such as raw CRTs have.
zoyd is offline
post #378 of 633 Old 08-14-2012, 02:12 PM - Thread Starter
I have added a new version with some extra patterns.
Im not sure why the brightness clip pattern show a different result as the AVSHD709 disk - I am investigating..
also I have skipped the AVCHD version and now there is only the strict version - this is to keep it all a bit more simple.
any comments please let me know
http://dl.dropbox.com/u/66942922/GCDb4_3_10.zip
post #379 of 633 Old 08-17-2012, 10:14 AM
djams's Avatar
Thanks visca - appreciate the meter position very much!
Regarding the brightness pattern - 17 is marked as reference black (?)
djams is offline
post #380 of 633 Old 08-17-2012, 10:42 AM
Liked: 716
sounds like it should be digital 16
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #381 of 633 Old 08-17-2012, 10:47 AM
Liked: 716
Which extra patterns does it have? I just recently burned b4.3.9 (regular AVCHD version).
BTW, what is wrong with the brightness clip pattern?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #382 of 633 Old 08-17-2012, 12:19 PM - Thread Starter
Correct I have marked the wrong level as reference - will fix this
the changes between 4.3.9 and 4.3.10 it the following:
added position pattern
added brightness pattern
added ramps for black, RGBCYM all to white
extended the length for the patterns in the basic section to 1 minute
post #383 of 633 Old 08-18-2012, 12:43 PM - Thread Starter
http://dl.dropbox.com/u/66942922/GCDb4_3_11.zip
latest version
this have the corrected brightness clip pattern and also added contrast clip pattern (all white)
post #384 of 633 Old 08-21-2012, 04:12 AM
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2137
I have download the disk for the first time today and while i was checking the file contents i found that the APL Patterns has no fixed RGB Triplet Background. From a quick check to some files i found these differencies:
Background Used for APL Patterns have these RGB Triplets:
1% APL Grayscale: RGB Triplet: 71,71,71
Color Checker APL : RGB Triplet: 71,71,71
0% White APL : RGB Triplet: 71,71,71
10% Window APL - 25 Amplitude @ All Saturation Levels: RGB Triplet: 64,64,64
50 Amplitude @ All Saturation Levels APL : RGB Triplet: 57,57,57
10% APL 75%A RGB Triplet: 51,51,51
100% Amplitude 25% Green RGB Triplet: 45,45,45
@ 10% APL Grayscale Patterns:
100% RGB Triplet: 45,45,45
90% RGB Triplet: 48,48,48
80% RGB Triplet: 50,50,50
70% RGB Triplet: 53,53,53
60% RGB Triplet: 55,55,55
50% RGB Triplet: 57,57,57
40% RGB Triplet: 60,60,60
30% RGB Triplet: 62,62,62
20% RGB Triplet: 65,65,65
10% RGB Triplet: 67,67,67
Because i haven't followed all previously posts, please tell me if that differencies at background values is normal, before burning the disk for testing to my setup.
* That version of disk i have examined: GCDb4_3_7_BLURAY
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #385 of 633 Old 08-21-2012, 04:22 AM
praz's Avatar
Liked: 26
Would it be possible to add window patterns from 90% to 109% in 1% increments? This would work well with the new contrast tool in CalMAN 5. Thanks.
praz is offline
post #386 of 633 Old 08-21-2012, 04:59 AM - Thread Starter
If you require the blu-ray version I will upload 4.3.11. give me 1 hour.
regarding the background difference between 1% and 10% WINDOWS apl. the difference you see is intentional.
the reason for that is the following.
1% window sizes are so small they dont really change the power output where the 10% windows are so big that a compensation in the background is required.
@praz
I will include the required patterns however it might be some time, going on holiday tomorrow, and when I get back I start a new job, so this will require some attention.
post #387 of 633 Old 08-21-2012, 05:47 AM
praz's Avatar
Liked: 26
@praz
Thank you. Very much appreciated.
praz is offline
post #388 of 633 Old 08-21-2012, 01:26 PM - Thread Starter
sorry for the delay. 4.3.11 bluray format
http://dl.dropbox.com/u/66942922/GCDb4_3_11_BluRay.zip
post #389 of 633 Old 08-22-2012, 04:20 AM - Thread Starter
Additional I can add that the 10% APL windows have an APL on 23% this it to prevent triggering ABL on plasma sets.
post #390 of 633 Old 08-24-2012, 04:19 AM
Killerbeenl's Avatar
Great disk Visca!!!
Only problem is on both latest AVCHD and BD version that if i choose patterns skipping to the next (ie 10% grayscale chapters) it skipped from 0% to 100%??
This happens on my iconbit 3D mediaplayer.
The Avchd disk has no problem.
Thanks for putting effort in this disk
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
Reply Display Calibration
