GCD - Gamut Calibration Disk - Page 2 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What format would you prefer for the HTPC?
.mp4 31 31.31%
.mkv 67 67.68%
others (please detail in thread) 1 1.01%
Voters: 99. You may not vote on this poll
 3Likes
post #31 of 633 Old 04-21-2012, 08:41 AM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
Originally Posted by visca blaugrana View Post
I am now ready to start encode the videos, but since that take ages I want to make sure i get the sequences right
I will start encode the first chapter when confirmed.
100% Luminance sweep: Red (Starting @ 0,25,50,75 & 100% saturation) in the following order Red, Green, Blue, Cyan, Magenta, Yellow
Is there any need of a 100% white either before or at the end?
No need for white in the sweeps and the order should be Red, Green, Blue, Yellow, Cyan, Magenta for the sweeps and the color calibration sequence is Red, Green, Blue, Yellow, Cyan, Magenta, White. Thanks!
zoyd is offline
post #32 of 633 Old 04-21-2012, 08:44 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Yes and for 75% Luminance sweep need 75% white.
anta1974 is online now
post #33 of 633 Old 04-21-2012, 09:03 AM - Thread Starter
visca blaugrana's Avatar
I have added a white at the end, so if not needed it should not get in the way.
each pattern will be on for 3 minutes, and if you press next it should take you to the next pattern.
I am using MultiAVCHD to author the ISO (not used it that much) so the menu system will be no ware near the level of the AVS disk, however it should be usable
Chapter 10 will be done in around 10 hours - So if I got time tomorrow I will upload chapter 1 as a beta, so please try it out and comment
visca blaugrana is offline
post #34 of 633 Old 04-21-2012, 09:09 AM
zoyd's Avatar
Liked: 1051
Sounds good, are you sure you want 3 minutes/pattern? I typically don't need a pattern up for more than 20 seconds and can hit pause if needed. That would save you considerable rendering time. I think there is a limit to the number of chapter markers in AVCHD format so watch out for that (and no pop-up menus unfortunately) but using chapter skips works fine.
zoyd is offline
post #35 of 633 Old 04-21-2012, 09:21 AM - Thread Starter
I will reduce the time to 1 minute, the reason for 3 minutes was that I have a profile that defaults to 3 minute for each chapter, but tsMuxeR should be able to create one for each 1 minute
post #36 of 633 Old 04-22-2012, 04:27 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
When the estimated it will be possible to test?
post #37 of 633 Old 04-22-2012, 08:06 AM - Thread Starter
attached is the first beta.
this only contain a 100% luminance saturation sweep
http://gupl.dk/678192/
if there is any comments please let me know.
my plans is:
adding the following
1. 100% luminance saturation sweep [R0,R25,R50,R75,R100, etc.]
2. 75% luminance saturation sweep [R0,R25,R50,R75,R100, etc.]
3. 50% luminance saturation sweep [R0,R25,R50,R75,R100, etc.]
4. 100/100 RGBYCMW
5. 100/75 RGBYCMW
6. 75/100 RGBYCMW
7. 75/75 RGBYCMW
remove unnecessary items in the menu structure
add 1% of all the above but on apl background
others??
post #38 of 633 Old 04-22-2012, 08:49 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Add,please, 75/75/75 pattern !!!!!
And please format mp4.
post #39 of 633 Old 04-22-2012, 09:17 AM - Thread Starter
75/75/75?
75%amplitude, 75%saturation 75%??
I will look at creating a mp4 version when I have all the encodings done.
post #40 of 633 Old 04-22-2012, 09:44 AM
AV Science Sales 4's Avatar
Originally Posted by anta1974 View Post
Very very thanx!
Why is the gamma=2.22 but gamma=2.20?
Mastering moniitor standard in US is 2.22. Camera gamma standard is 2.2. I couldn't sleep at night and would consider calibration efforts a complete failure unless I was able to create a custom curve at 2.21 and be able to reach a de with a cheap $400 probe of less than 0.1.
AV Science Sales 4 is offline
post #41 of 633 Old 04-22-2012, 10:30 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
75% lightness
post #42 of 633 Old 04-22-2012, 11:58 AM - Thread Starter
I am only a amateur but is amplitude not the same as lightness?
post #43 of 633 Old 04-22-2012, 12:14 PM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #44 of 633 Old 04-22-2012, 01:34 PM
zoyd's Avatar
Liked: 1051
The first sweep looks great! Easy navigation and nice clean look, very well done. I measured it against the AVSHD 100% sweep and the agreement was very good, luminances are all within 1% and the xy locations all agree to <=0.003 (most < .001)
zoyd is offline
post #45 of 633 Old 04-22-2012, 02:26 PM - Thread Starter
thank you for the feedback
Please ignore link - menu problem
latest beta including 100, 75 & 50% luminance sweeps
please test and report issues
post #46 of 633 Old 04-22-2012, 02:56 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Very big thank you for your work!!!
post #47 of 633 Old 04-22-2012, 03:06 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
hey guys, am i the only one that cant see the link or attachment? i would love to take a peek at this. thanks
1forsnow is online now
post #48 of 633 Old 04-22-2012, 03:08 PM - Thread Starter
Give me 5 min, just fixing a menu problem
post #49 of 633 Old 04-22-2012, 03:17 PM - Thread Starter
Please find beta 2.1
http://gupl.dk/678225/
this include
if any problems please let me know.
I will be away with work next week, so a new upload will not available to at the earliest late next week.
Thank you for any comments
post #50 of 633 Old 04-23-2012, 08:40 AM
zoyd's Avatar
Liked: 1051
beta 2.1 looks good, there is one odd measurement for magenta 50/50 (see attached). This could be my display but 75 and 100 don't show the same behavior. If this shows up in testing on another display type it could be a bad pattern. The curvature in the green saturation tracking is normal for my display.
zoyd is offline
post #51 of 633 Old 04-23-2012, 12:44 PM - Thread Starter
thank you for letting me know.
the source pattern for 50/50 magenta is correct (as per yourself), however when encoding, something could have gone wrong. But just to eliminate your display please use the attached 2.1.1, this only include the 50/50 magenta, and I have verified that it is correct (by reversing from the video file back to a 24bit TGA file.)
please let me know how it looks
http://gupl.dk/678273/
post #52 of 633 Old 04-23-2012, 03:40 PM - Thread Starter
What I meant that the pattern it's correct is that the RGB digital values is as per the excel spreadsheet further up.
post #53 of 633 Old 04-23-2012, 04:53 PM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #54 of 633 Old 04-25-2012, 11:38 AM - Thread Starter
Please find b3.0
http://gupl.dk/678377/
this include
4. 100/100 RGBYCMW
5. 100/75 RGBYCMW
6. 75/100 RGBYCMW
7. 75/75 RGBYCMW
please test and report any problems.
post #55 of 633 Old 04-25-2012, 11:45 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Very thanx!!!!!!
post #56 of 633 Old 04-25-2012, 12:48 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Why use magenta 50\\50 in HCFR?
Is it right 50% saturation 100% luminance?
post #57 of 633 Old 04-25-2012, 01:36 PM - Thread Starter
You Can use 50% luminance as long you use a 50% White as reference
post #58 of 633 Old 04-25-2012, 01:53 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Thank you very match!!!
Very thanx!!!
Hugest, greatest thank you!!!
I am very happy that he learned this.
post #59 of 633 Old 04-26-2012, 03:01 PM - Thread Starter
Just did some my self and as far as I can see the Magenta 50/50 is ok (Beta 3.0) see attached this is on a Samsung LCD
I am planing on adding the following
100 Saturation - Luminance Sweep (R100%,R75%,R50%,R25% etc....)
75 Saturation - Luminance Sweep (R100%,R75%,R50%,R25% etc....)
50 Saturation - Luminance Sweep (R100%,R75%,R50%,R25% etc....)
Any other patterns needed?
when all pattern is correct and done, I will start working on the 1% APL version
post #60 of 633 Old 04-27-2012, 04:53 AM
realzven's Avatar
Liked: 84
thanks for your great works
realzven is offline
Reply Display Calibration
