GCD - Gamut Calibration Disk - Page 4 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What format would you prefer for the HTPC?
.mp4 32 31.68%
.mkv 68 67.33%
others (please detail in thread) 1 0.99%
Voters: 101. You may not vote on this poll
 3Likes
post #91 of 633 Old 05-04-2012, 01:50 PM - Thread Starter
visca blaugrana's Avatar
Ok I will add grey scale patterns at10% windows no problem
visca blaugrana is offline
post #92 of 633 Old 05-04-2012, 02:02 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
I've made it through all the saturation sweeps and some of the primaries/secondaries sweeps and they look good so far. I have one suggestion for work flow and that is to place the calibration sweeps right after the saturation sweeps for each luminance level:
100% luminance - Saturation Sweep
100% luminance - 100% Saturation: Primaries/Secondaries Sweep
100% luminance - 75% Saturation: Primaries/Secondaries Sweep
100% luminance - 50% Saturation: Primaries/Secondaries Sweep
75% luminance - Saturation Sweep
75% luminance - 100% Saturation: Primaries/Secondaries Sweep
75% luminance - 75% Saturation: Primaries/Secondaries Sweep
75% luminance - 50% Saturation: Primaries/Secondaries Sweep
50% luminance - Saturation Sweep
50% luminance - 100% Saturation: Primaries/Secondaries Sweep
50% luminance - 75% Saturation: Primaries/Secondaries Sweep
50% luminance - 50% Saturation: Primaries/Secondaries Sweep
25% luminance - Saturation Sweep
100% Saturation - luminance Sweep
75% Saturation - luminance Sweep
50% Saturation - luminance Sweep
25% Saturation - luminance Sweep
I don't think I would ever use the luminance sweeps but someone else might find them useful.
zoyd is offline
post #93 of 633 Old 05-04-2012, 02:34 PM - Thread Starter
Zoyd,
thank you for your excessive testing. I am using the luminance sweeps for chromapure.
I am looking in to a new menu system to make it all a bit more easy to use.
not sure if its a general problem but by Phillips BDP9500 take about 1-2 seconds to change item in the menu so will have a look on what other software I can find to author the disk, If I have no joy I will have a look in optimizing the workflow (well I will look in to this no matter what men u system I use.)
post #94 of 633 Old 05-04-2012, 02:44 PM
zoyd's Avatar
Liked: 1064
zoyd is offline
post #95 of 633 Old 05-05-2012, 03:51 AM - Thread Starter
I am having a play with adobe Encore to author the Disk
could you please try to see if the attached ISO file will play on your player
(dont work on PS3 - test of solution in progress)
the iso file contain a bit of menu navigation and 2 test patterns
its just to know if I should proceed down this route - the actual patterns are incorrect and chapter splits are not set either, further more do I have some resolution problems.
it work on by BPD9500.
the advantages going this way is:
sub-menues
fast navigation
more customizable
please let me know if it work?
post #96 of 633 Old 05-05-2012, 06:39 AM - Thread Starter
I now have an ISO that work on both my bluray players at home.
could interested please test this
http://www.sendspace.com/file/3rxk3c
this is just a test of the navigation system.
since I now can create sub-menues is there any preferences on how this would be used best? I was thinking something like this
post #97 of 633 Old 05-05-2012, 06:55 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
When they APL pattern?
anta1974 is offline
post #98 of 633 Old 05-05-2012, 07:05 AM - Thread Starter
due to the sluggish menu system in MultiAVCHD is the priorety now to setup the menu system in Adobe Encore. When this is done I will start creating the patterns for APL, I dont really want to put a time scale on it.
post #99 of 633 Old 05-05-2012, 07:10 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Thank you very match!!!
Very thanx!!!
anta1974 is offline
post #100 of 633 Old 05-05-2012, 07:17 AM
zoyd's Avatar
Liked: 1064
This did not play on my PS3, it shows up as "Data Disk" instead of "AVCHD"
edit: I see you have a new test disk, I tried TEST_BD_ISO and it did not work, I'll try the other one.
zoyd is offline
post #101 of 633 Old 05-05-2012, 07:32 AM - Thread Starter
I uploaded 2 versions of the ISO file, did you use the one that I link to now?
could you check the iso file on your laptop.
in the BDMV folder there should be this file "index.bdmv.bak"
post #102 of 633 Old 05-05-2012, 07:54 AM
zoyd's Avatar
Liked: 1064
I just tested the second disk Adobe_Encore_test and it worked fine. The proposed menu structure looks good as long as you can pop back either 1 level or to the top level. Can you also add a gray scale to the 1% APL patterns? APL background should be full field 25% so as not to trigger ABL on plasmas.
zoyd is offline
post #103 of 633 Old 05-05-2012, 02:29 PM - Thread Starter
http://www.sendspace.com/file/1zmaeq
latest copy using adobe encore
for some reason when pressing menu in a pattern it goes to the same menu, despite I have set it to go to another.
the layout is not brilliant and need some working. If anyone is good at stuff like that and fancy helping out let me know
Thank You
post #104 of 633 Old 05-05-2012, 03:35 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
^^^^^only an 18mb file? im having a hard time downloading it....
1forsnow is offline
post #105 of 633 Old 05-05-2012, 04:03 PM
zoyd's Avatar
Liked: 1064
Thank You
testing and working ok, hitting menu within a pattern or at the top menu always redirects to 25% luminance page?? I could take a look at your .ncor file if you want.
zoyd is offline
post #106 of 633 Old 05-06-2012, 01:05 AM - Thread Starter
Yes I has the same problem, however when simulating in encore its ok, I will upload the file when I get on the computer thank you.
Do you know if the .ncor file from the avs disk is public available?
post #107 of 633 Old 05-06-2012, 07:13 AM - Thread Starter
please find the .ncor file.
http://www.sendspace.com/file/qz16kl
if you find anything please let me know
post #108 of 633 Old 05-06-2012, 07:41 AM
zoyd's Avatar
Liked: 1064
Thanks but it won't import in encore (Mac version), maybe it's not compatible with Mac version. I'm not an encore expert anyway so I don't know if I would spot anything. You should PM Alluringreality and see if he would help.
I have some more pattern specs for your color test menu which currently has the 2 skin tones. I will post RGB values and coordinates for the 15 EBU recommend swatches.
zoyd is offline
post #109 of 633 Old 05-07-2012, 04:16 AM - Thread Starter
I am looking in to optimizing the menu layout, and to be hones I am not happy with the layout (both visual and functional)
I would like to repeat what i wrote earlier if anyone would have any interest helping with menu pictures etc please let me know.
also is there any suggestions on what patterns should be together on same menu - to minimize navigation? (workflow)
eventual I will be looking in to pop-up menus - to navigate across sections, but this is not until I got a menu system I think works
post #110 of 633 Old 05-07-2012, 04:40 AM - Thread Starter
I was thinking something like the following
Main Menu:
10% Windows
1% Windows APL
Skin Tones
10% Windows:
100% Saturation
75% Saturation
50% Saturation
25% Saturation
100% Luminance
75% Luminance
50% Luminance
25% Luminance
Grey Scale
10pt gray Scale
20pt Grey Scale
where bald/underlined is a separate menu?
The Skin menu would contain the skin patterns
The 1% Windows APL would be build the same way as the 10%
any comments is much appreciated
post #111 of 633 Old 05-07-2012, 06:13 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
1000% Saturation -mistake!
anta1974 is offline
post #112 of 633 Old 05-07-2012, 06:14 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Please add a greyscale.
anta1974 is offline
post #113 of 633 Old 05-07-2012, 06:17 AM - Thread Starter
Grey scale will be added, just misted it out, the main point of the above is to get the menu structure right.
Not sure what you mean by 100% saturation is wrong?
Oh 1000% - just a typo
post #114 of 633 Old 05-07-2012, 06:29 AM
zoyd's Avatar
Liked: 1064
Suggestion: Skin tones chapter->EBU Test Colours
Included test colours will be:
Code:
EBU 1
Dark Skin
EBU 2
Light Skin
EBU 3
Light Greyish Red
EBU 4
Light Yellow Green
EBU 5
Light Bluish Green
EBU 6
Light Violet
EBU 7
Foliage
EBU 8
Medium Red
EBU 9
Medium Green
EBU 10
Medium Blue
EBU 11
Dark Red
EBU 12
Dark Green
EBU 13
Dark Blue
EBU 14
Medium Yellow Red
EBU 15
Medium Purple
For menu organization I would simplify and pull out the non-essential sweeps from each heading so that for example:
100% Saturation contains the prim/sec sweeps at 100% saturation + just the luminance sweep at 100% sat
100% Luminance contains the prim/sec sweeps at 100% luminance + just the saturation sweep at 100% lum
zoyd is offline
post #115 of 633 Old 05-07-2012, 07:41 AM - Thread Starter
Zoyd,
please forward the EBU R'G'B details when you got them ready. do you think maybe a separate submenu under 10% & 1% windows would be better? I can See EBU 1&2 and partly EBU8 is skin tones but the remaining is more general color test patterns?
regarding menu structure,
my thought behind it was not to have to navigate through menus to much, however the simple the better of course also apply, I think some trials is required.
I think I will change it so that instead of having a box with some text (as it is now) maybe a picture of the pattern and some text either above or below would be better (sort of like it was with the MultiAVCHD version)
attached is a test mimic of the menu:
what do you think?
post #116 of 633 Old 05-07-2012, 11:48 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Very great!!!
anta1974 is offline
post #117 of 633 Old 05-07-2012, 12:02 PM
zoyd's Avatar
Liked: 1064
Zoyd,
what do you think?
as anta1974 says, very great!
I decided to go with the more widely used color checker series instead of EBU.
dark skin
light skin
blue sky
foliage
blue flower
bluish green
orange
purplish blue
moderate red
purple
yellow green
orange yellow
Updated spreadsheet with R'G'B' for those is attached.
edit: version 3 of the spreadsheet with added targets for camera gamma and color checker patterns.
GCD_targets.xlsx 3.zip 85.2421875k . file
zoyd is offline
post #118 of 633 Old 05-07-2012, 01:57 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
awesome! cant wait to try it out...well done!
1forsnow is offline
post #119 of 633 Old 05-08-2012, 10:36 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
When they Fields pattern for LED-backlight?
Оr APL will be sufficient?
anta1974 is offline
post #120 of 633 Old 05-08-2012, 01:14 PM - Thread Starter
Latest beta
http://www.sendspace.com/file/q10n71
I will now start focusing on new patterns
but please comment on any thing.
If you think there is to many items in the menus please let me know. I cant seam to make up my mind
Zoyd
Thank you for your great help with this disk
Reply Display Calibration
