KRP 500-M Calibration through the Internet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-20-2012, 12:58 PM - Thread Starter
fixuis's Avatar
Is it possible to do this? I don't have access to an ISF calibrator where I live. Thanks.
fixuis is offline
post #2 of 5 Old 04-20-2012, 01:09 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
The pros Travel or they would be out of business. You didn't say where you are located, it would be helpful. Also post your location and request in the tread up top that the pros use to tell the everyone where they are going to be located.
http://www.avsforum.com/avs-vb/showthread.php?t=586330
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 5 Old 04-20-2012, 01:11 PM - Thread Starter
fixuis's Avatar
I'm located in Karachi, Pakistan. I'm sure there are no ISF pro's here or any that would be willing to travel so that's why I ask what I ask.
fixuis is offline
post #4 of 5 Old 04-20-2012, 01:25 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
The answer sadly is NO. To calibrate a device you need to have your equipment in front of the Device. A meter is use to take light and color readings of the set and there is no way to do that remotely. If you can afford the equipment and have the time to educate yourself, you best option would be to buy the equipment and do the calibration yourself.
If nothing else, download the AVS 709 calibrations disk and set the user level options that can be set without equipment, you may be happy with that and need not go farther.
http://www.avsforum.com/avs-vb/showthread.php?t=948496
Doug
post #5 of 5 Old 04-22-2012, 09:24 AM - Thread Starter
fixuis's Avatar
thanks for the advice, ill try the steps you listed :-)
fixuis is offline
Reply Display Calibration
