Yay finally!!! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 68 Old 04-21-2012, 05:03 PM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
Originally Posted by kanti123 View Post
So, you're saying dE94 is good for measuring Gamut?
definitely, I wouldn't use any other formula for gamut
the LCH breakdown is an extension of dE94 in CalMAN
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #32 of 68 Old 04-21-2012, 05:05 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
ah okay, so dEUV for gray scale, dE94 for Gamut. Nice, I'm going to write down my current setting and bump up my contrast to mids 90s like you suggested.
kanti123 is offline
post #33 of 68 Old 04-21-2012, 05:07 PM
Liked: 716
the quickview DDC workflow in CalMANv4 already uses dE94 for gamut
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #34 of 68 Old 04-21-2012, 05:11 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
I have never use Quickview DDC in Calman4.
kanti123 is offline
post #35 of 68 Old 04-21-2012, 05:11 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
also, with dEUV the better the RGB percentages the lower the dE and all grayscale points are treated equally since the L portion of the formula is removed
By default CalMAN doesn't use L for dE76 or dE94 on grayscale readings, but at least the measured luminance level is used to determine the L*a*b* values.
The point of any dE formula is to report a consistent value that correlates to a visible difference. So a dE of 2 between to shades of blue is a similiar difference for two shades for yellow that are seperated by a dE of 2.
In that regard deUV is a total failure, it's values aren't consistent from either one shade to the next and is even worse when comparing targets at different luminance levels.
sotti is offline
post #36 of 68 Old 04-21-2012, 05:19 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
So, in your point of view. You're saying when measuring Gamut and Grayscale, I should just use dE94 across the board would be more effective and efficient?
kanti123 is offline
post #37 of 68 Old 04-21-2012, 05:25 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Looking at dE94 is going to give you a better idea of how much error you'll actually percieve across the board.
When correctly calibrated you should be able to get dE94 values <2 for grayscale.
sotti is offline
post #38 of 68 Old 04-21-2012, 05:25 PM
Liked: 716
what about dELUV? is the UV part the problem or that the measured luminance level is not used to determine the L*U*V* values?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #39 of 68 Old 04-21-2012, 05:26 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
Right, I will try this out now.
kanti123 is offline
post #40 of 68 Old 04-21-2012, 05:31 PM
Liked: 716
see attached...
low dEUV values contribute to even lower dE94 values
QuickView Grayscale dE94.pdf 50.05078125k . file
QuickView Grayscale.pdf 29.3037109375k . file
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #41 of 68 Old 04-21-2012, 05:35 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
Ah, I see that now. Lest margin of error and more precise. BTW to use dE94, I go to Settings>Miscellaneous and change DeltaE Formular from deUV to de94 under Interative Target?
kanti123 is offline
post #42 of 68 Old 04-21-2012, 06:32 PM
Liked: 716
no, you right click the dE section in the workflow, select properties and then select the dE formula you want from the top right of the screen
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #43 of 68 Old 04-21-2012, 06:58 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
okay, got it. Hey Adjusting Gamut is really annoying. Any tips on how should I approach this?
kanti123 is offline
post #44 of 68 Old 04-21-2012, 07:08 PM
Liked: 716
for starters, you can set color space to "auto" and set color to get red luminance as close as possible and the secondary hues a low as possible overall
later on, you can use "custom" color space to dial in LCH for each primary and secondary
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #45 of 68 Old 04-21-2012, 07:13 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
So, while I'm in auto for color space, I would adjust Color and Tint to achieve this correct?. BTW I have attached my new setting with contrast being at mid 90s. Its a little red, but that'll do for now.
QuickView Grayscale.pdf 58.2724609375k . file
kanti123 is offline
post #46 of 68 Old 04-21-2012, 07:18 PM
Liked: 716
looks good from 20% on up, looks like your meter can't read 10% properly
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #47 of 68 Old 04-21-2012, 07:18 PM
Liked: 716
yes
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #48 of 68 Old 04-21-2012, 07:48 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
yes
okay, this gamut adjustment is starting to piss me off LOL
Adjust Color Gamut.pdf 116.76171875k . file
kanti123 is offline
post #49 of 68 Old 04-21-2012, 09:57 PM
Liked: 716
you need to turn the color control up until the red luminance error is as close to zero as possible... it's way too low right now
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #50 of 68 Old 04-22-2012, 05:31 AM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
And that would be C chart? CalMAN said you have to get all the luminance to match each other. Thats how it throws me off
kanti123 is offline
post #51 of 68 Old 04-22-2012, 05:46 AM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
You do but you get Red as close as you can first.
L = Luma Y
C = Saturation y
H = Hue x
Primaries get Luma matched, Secondaries get Hue matched... and then have fun balancing back and forth for hours until it's all as perfect as can be (at this point a little OCD is required ).
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #52 of 68 Old 04-22-2012, 07:13 AM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
L = Luma Y
C = Saturation y
H = Hue x
Jason
The OCD part I have it get primary Luma matched like this? and ignore everything else? Had to turn up color to 80 to get red to 0 in L chart. Weird
Update: I think I got it down now, not perfect but close to 0 enough.
Gamut After.pdf 115.986328125k . file
kanti123 is offline
post #53 of 68 Old 04-22-2012, 10:20 AM
Liked: 716
is the first attachment auto color space and the second custom?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #54 of 68 Old 04-22-2012, 10:32 AM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
No both custom, I think I have my color too high, it's over saturated to me. My settings for color is 79 tint 50/50
Color space,
R G B
45 1 0 Red
0 46 0 Green
0 2 78 Blue
45 50 1 yellow
0 48 50 cyan
42 0 37 magenta
kanti123 is offline
post #55 of 68 Old 04-22-2012, 11:25 AM
Liked: 716
Color space,
R G B
45 1 0 Red
0 46 0 Green
0 2 78 Blue
45 50 1 yellow
0 48 50 cyan
42 0 37 magenta
for the after result, can you lower cyan and magenta luminance?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #56 of 68 Old 04-22-2012, 11:52 AM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
I think I can, right now my picture looks too saturated. I also notice my blue luminance is very low. By adding green 1 - 2 ticks it adds luma significantly.
Update: I got every color nice and tweaked, just blue. For some reason Delta C is over 15 while other are at close to zero. Any tips on this? This setting make my picture looks better now, no more overly saturation.
Enhanced Gamut .pdf 116.4111328125k . file
kanti123 is offline
post #57 of 68 Old 04-23-2012, 05:24 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
Can any one take a look at my Delta C chart? my blue is waayyy high. Already max out my blue in color space (100) had to turn up green and red.
BlueDeltaC-Problem.pdf 116.3623046875k . file
kanti123 is offline
post #58 of 68 Old 04-24-2012, 09:41 AM
Liked: 716
do not turn up green and red in the cms section for blue, it will desaturate the blue primary further and make things a lot worse
also, use dE94 in the datagrid, not dE76
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #59 of 68 Old 04-24-2012, 10:43 AM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
I can't change that for some reason. I click on de74 and go to property. There's no option in there.
kanti123 is offline
post #60 of 68 Old 04-24-2012, 11:44 AM
Liked: 716
you right click the datagrid and select the add row option and choose dE94 then you highlight dE76 and select remove row
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
Reply Display Calibration
