i1 Display pro plus HCFR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-26-2012, 11:55 AM - Thread Starter
ndaa75's Avatar
General question all, does the i1display pro work with the HCFR freeware?
Im thinking of buying one, infact i should have bought one instead of the i1D2
as im under the impression the i1 display pro is effectively the renamed i1 display 3 which altogether is the better meter?
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #2 of 8 Old 04-26-2012, 12:16 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
It won't work with the regular HCFR freeware, but it will work with this enhanced version:
http://www.avsforum.com/avs-vb/showthread.php?t=1393853
Kilgore is offline
post #3 of 8 Old 04-27-2012, 06:33 PM
kanti123's Avatar
Quoted: 45 Post(s)
Liked: 39
I was thinking of buying it too, does any one know the different between i1d pro and i1d pro UV version? New egg have them both at 649 dollars.
kanti123 is offline
post #4 of 8 Old 04-27-2012, 06:38 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
The UV cut is not needed for HT use (but new units will still work). Those are good prices for new units but many here (me included) have been scoring great used/like new units on ebay for about half that amount or less.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #5 of 8 Old 04-27-2012, 08:57 PM
fallengt's Avatar
Uh... The i1Display Pro and i1 Pro are completely different units.
fallengt is offline
post #6 of 8 Old 04-27-2012, 11:01 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Good catch, although it was fairly clear to me he was meaning the i1Pro (no UV cut version of the i1Dpro and they are not $650).
Jason
post #7 of 8 Old 04-28-2012, 12:53 AM
fallengt's Avatar
Jason
Well, OP was talking about i1Display Pro and kanti wanna get 1( i1Display Pro or i1 Pro ?), so just to be clear that he isnt mistaken.
fallengt is offline
post #8 of 8 Old 04-28-2012, 01:00 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Indeed, as I said 'good catch'. It certainly is a common mistake since the naming is so similar.
Jason
Reply Display Calibration
