Plasma Calibration - Colour Accuracy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-30-2012, 11:24 AM - Thread Starter
ndaa75's Avatar
Is it normal for plasmas to suffer from colour accuracy?
Im struggling to get my saturation points in line with the reference.
In all, colours are undersaturated at 25, 50 and 75% but have above target 'Y' luminance value. Ive found that with the Samsung CMS, which is the RGB type, it is impossible increase saturation values without any impact to brightness as both the colour main slider and primary colour sliders in the colour space setting, control both luminance and saturation at the same time.
Im just wondering whether this is a common issue.
Strangely, I did for the hell of it, try full screen saturation fields which yielded much better results than the window fields.
Plasmas seem difficult.
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #2 of 10 Old 04-30-2012, 01:36 PM
PlasmaPZ80U's Avatar
Quoted: 2193 Post(s)
Liked: 658
you can never increase saturation with a CMS (unless the CMS defaults to settings that decrease saturation from the display's native gamut, which is unlikely)
this is not a plasma issue; rather just sets that have undersaturated gamuts versus the Rec. 709 targets.
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #3 of 10 Old 04-30-2012, 02:09 PM - Thread Starter
ndaa75's Avatar
I dont think thats true. Using the CIE graph I can move the 75% saturation point on my Samsung plasma along the x axis by increasing either the colour slider or using the red slider in the colour space setting. Problem is both controls also increase luminance at the same time.
ndaa75 is offline
post #4 of 10 Old 04-30-2012, 02:59 PM
buzzard767's Avatar
Quoted: 1655 Post(s)
Liked: 2436
The Color control is not part of the CMS.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #5 of 10 Old 04-30-2012, 03:10 PM - Thread Starter
ndaa75's Avatar
Maybe not, but upping the value increases the saturation and brightness, effecting all colours. Likewise using the red slider in the RED colour space option in the Samsung CMS, for example, also increases both saturation and brightness, although this only impacts red.
ndaa75 is offline
post #6 of 10 Old 04-30-2012, 03:27 PM
buzzard767's Avatar
Liked: 2436
Yes, it's Chroma Gain, nothing new.
Buzz
post #7 of 10 Old 04-30-2012, 04:13 PM
Liked: 658
if you try to fix undersaturated colors by using the chroma gain you will improve saturation at the expense of lightness (lightness will become way too high)... so not really worth it
post #8 of 10 Old 04-30-2012, 11:41 PM - Thread Starter
ndaa75's Avatar
Yes, understood thanks!
So is this 'normal'?
ndaa75 is offline
post #9 of 10 Old 05-01-2012, 03:14 AM
buzzard767's Avatar
Liked: 2436
Pretty much. Considering your Samsung with a full CMS, you might have to use the Color control to mitigate the effects of post calibration red push if your TV has this trait. The side effect is that the luminance of blue and green is reduced as well but it's better than looking at lobster faces.
Buzz
post #10 of 10 Old 05-01-2012, 05:31 AM - Thread Starter
ndaa75's Avatar
Absolutely!
ndaa75 is offline
Reply Display Calibration
