Calman v4 autocal for color gamut not working with Mini3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-01-2012, 10:52 AM - Thread Starter
Dmiraclejr's Avatar
Last week I bought an autocal package that Spectracal put together for me that consisted of Calman v4, a C6 meter, and a Lumagen Mini3D. I am using it with the following system:
Panasonic AR-100U projector
Onkyo NT 808 receiver (hdmi switcher)
50 foot HDMI cable
03112012 firmware for Mini3D (latest)
Everything works fine (without calibration) with the Mini3D out of the loop. When I try to autocal with the Mini3D the gamma and greyscale seem to calibrate correctly. But when it goes to do the color gamut all hell breaks loose. The Mini3D will put up the correct test pattern for a color or two. Then all the sudden say it is suppose to be working on blue, the Mini3D will be putting up a red pattern! I have seen a case where it was suppose to be working on green and put up a blue pattern which of course messes things up.
For further info I got into the menu system of the Mini and the "Reference" color patters were fine but when I looked at the "Adjustable" color pattern for blue it showed red there too.
One last problem. When all of this happens the Mini will go into an output mode that looks like a negative from the old days of film photography. Changing from RGB to Yxxxxx etc does not fix it; only a factory reset will put it back to working properly..... that is until I try to calibrate color gamut again.
I have contacted both SpectraCal and Lumagen but wanted to see if I could get some ideas for a solution here.
Thanks for any help with this problem you can provide.
Dmiraclejr is offline
post #2 of 14 Old 05-01-2012, 12:22 PM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Tom Huffman made a relevant post in the ChromaPure thread - http://www.avsforum.com/avs-vb/showp...postcount=2482
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #3 of 14 Old 05-01-2012, 12:33 PM
Quoted: 46 Post(s)
Liked: 61
I tried it on my new Sharp this weekend and it was crazy on the gamut.
Mike
wmwilker is offline
post #4 of 14 Old 05-01-2012, 02:07 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
AutoCal on the gamut is a bit of a work in progress in CalMANv4.
It can do a good job, but only on displays that have a nicely over saturated display to begin with. Make sure you've got a dE threshold set to probably something around 2 for gamut autocal.
I'd recommend using interactive + DDC.
CalMAN 5 is coming soon and it's got a completely updated gamut autocal algorithm that does a much better job.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #5 of 14 Old 05-02-2012, 06:53 AM - Thread Starter
Dmiraclejr's Avatar
Last night I made sure I had the dE set to 2.5 and used the interactive DDC to get through the gamut and actually made it through the whole Radiance workflow. Great I thought, at least this will work with the temporary workaround for gamut until v5 comes out. Wrong! Although I had made it through the workflow with all the charts looking good, the actual picture on the display looks like that negative from film photography I mentioned in the earlier post.
I did find out that display looks wrong for any CMS slot I have used with Calman (say CMS 1 and 2) but I can switch the Mini back to the default CMS 0 and everything goes back to looking correct (except with no calibration of course).
This is getting very disheartening since I have well over $2000 and 20 hours of time, and still have not gotten one single calibration that was usable from "autocal". I expected some learning curve even with the autocal, and I have learned quite a bit, but this is getting ridiculous.!!
Anyone have Calman v4 working correctly with a Mini3D?
post #6 of 14 Old 05-02-2012, 09:10 AM
derekjsmith's Avatar
Liked: 116
Sounds like a firmware or setup issue with the Radiance. We test these setups all the time without issue. What firmware are you running on the Mini3D? What are the values on the Mini UI for CMS do you have when you get this effect?
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #7 of 14 Old 05-02-2012, 09:31 AM - Thread Starter
Dmiraclejr's Avatar
The firmware is "Production 031112" which is the latest.
What values on the Mini UI do you mean? The x,y,Y for the different colors?
post #8 of 14 Old 05-02-2012, 11:33 AM
Liked: 116
Yes or the RGB absolute values for each color.
Derek
post #9 of 14 Old 05-02-2012, 01:18 PM
Quoted: 46 Post(s)
Liked: 61
there is a 031612 update that has to do with color.
Mike
wmwilker is offline
post #10 of 14 Old 05-02-2012, 04:53 PM - Thread Starter
Dmiraclejr's Avatar
Here are some numbers from the Mini. Hopefully they are what you asked for.
Color, SubR, SubG, SubB
White, 217,319,309
Red, 0,19,2
Green, 24,0,0
Blue, 0,1,0
Yellow, 0,0,0
Cyan, 0,0,0
Magenta, 0,0,0
Thanks for the heads up on the new fw too.
post #11 of 14 Old 05-03-2012, 10:29 AM
Liked: 116
White, 217,319,309
Red, 0,19,2
Green, 24,0,0
Blue, 0,1,0
Yellow, 0,0,0
Cyan, 0,0,0
Magenta, 0,0,0
What do the grayscale or whites look like with these settings?
Derek
post #12 of 14 Old 05-04-2012, 09:37 AM - Thread Starter
Dmiraclejr's Avatar
I am not really sure since I had inadvertently already cleared them out of the Mini. But I do have an update.
With some help from the Calman Support Team I have discovered a couple of things.
First the workarounds. For my situation the autocal is indeed not working correctly with my Mini (looking forward to v5) and using the interactive mode instead of auto mostly works. There is a problem when you "drag" the gamut luminances toward the 0 target line. If there is a high difference say 150+ give or take and try to move it to 0 all at once, the color patterns put up by the Mini may go haywire. For instance say the blue is sitting on 200 and you drag it all the way down to 0 it will likely put up a red test pattern and mess things up. Happened while dragging green a long way too..... it put up a blue pattern. The solution I found was to do it a little at a time (about half) say from 200 down to 100, then to 50, then to 25, then to 0. Doesn't take much longer and it does not mess things up. Again I am very much looking forward to v5.
Secondly I realized some information that most of you already know but me being new to this sadly did not.
You cannot drag color gamut on the CIE chart that is residing within the triangle (color space). This can mess things up.
It is very difficult to get a good calibration for a projector for a condition with lots of ambient light. Just expect to get a good calibration in a dark room and don't expect much with lots of ambient light. I assume flat panels do much better.
Finally I will say that once I got a nice calibration last night with no ambient light the projector screen looked very good. Frozen Planet on Discovery especially.
Sorry for the long post but wanted to help out any other unassuming person new to this calibration thing and maybe save them some trouble.
Thanks for everyone's advice and help.
post #13 of 14 Old 05-04-2012, 10:20 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
You know one thing might be that you have a bad serial adapter.
Try getting an FTDI USB to serial adapter and see if that doesn't clear things up.
The issues you're describing sounds like the communication with the lumagen is going haywire. I've got a lumagen on my desk that I use to test with frequently, with a bad serial adapter I even saw blue screens. With a good serial adapter it works flawlessly.
Here's a post on our forums where a user was having similiar issues and switching the serial adapter cleared it all up.
http://www.spectracal.com/forum/view...hp?f=59&t=3714
Joel Barsotti
SpectraCal
sotti is offline
post #14 of 14 Old 05-04-2012, 10:44 AM - Thread Starter
Dmiraclejr's Avatar
Actually I am already using a FTDI USB serial adapter.
Reply Display Calibration
