meter distance from plasma/lcd screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-02-2012, 07:28 AM - Thread Starter
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
Is there a recommended maximum distance from the face of a LCD or plasma panel to the meter? I have an i1Pro and an i1D2. On my neighbors setup, the panel is built into a cabinet, and the meters cannot be used with the counter weights. I can set the meters on a tripod, but can not get closer than 15" from the face of the panel. Is this too far? or can this be treated like a projector set up?
thanks
vega509 is offline
post #2 of 7 Old 05-02-2012, 08:53 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
thanks
Make sure the room is Dark, and you are good to go.
Oh one thing to keep in mind. With that distance the D2 is going to be reading a lot more of the screen than in contact mode...
The i1pro will be looking at a spot about 3.5" round and the C6 (no clue how the D2 measures up to c6 in FOV) would be about 6" Need to keep this in mind if using small windows and menu location.
Viewing Angle Chart.pdf 74.337890625k . file
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 7 Old 05-02-2012, 10:47 AM
jimwhite's Avatar
Set the tripod with 2 legs against the cabinet and extend the back leg to tilt the meter closer to the screen . :-)
Jim White
St. Petersburg, FL
jimwhite is offline
post #4 of 7 Old 05-02-2012, 11:29 AM - Thread Starter
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
thanks for the replies airscapes and jimwhite, I'll try the tripod method, I always work in a dark room.
vega509 is offline
post #5 of 7 Old 05-02-2012, 07:56 PM - Thread Starter
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
The closest I could get to the screen was 5" on the tripod. With the room completely dark, I ran a 10 pt grayscale, then got my neighbor to hold the meter against the set and ran another 10 pt grayscale.
The gamma, luminance, color temp,and rgb charts are almost identical. Looking at the data, at 100%, the Y values on the runs were 101 on the screen, and at 5", 97, or 29.48 ftL and 28.31ftL.
I realize the light output will fall as distance increases. Will any other aspect change as well? or am I reading too much into this?
vega509 is offline
post #6 of 7 Old 05-02-2012, 09:05 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
To much
you are fine!
Doug
post #7 of 7 Old 05-03-2012, 08:42 AM - Thread Starter
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
thanks once again !!!
vega509 is offline
Reply Display Calibration
