W/B High Low R,G,B Sliders How to Use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-02-2012, 09:25 AM - Thread Starter
robert5545's Avatar
White Balance Questions,
For many Flat Screens there are W/B Red, Blue, Green, High and Low sliders for picture and video adjustment.
I can not find any explanation anywhere on how to properly use these adjustments sliders.
Can someone explain how to use these controls to produce better video and pictures.
Where is there a site that explains the Video Picture setting for large screen Plasmas, or LCD's?
robert5545 is offline
post #2 of 3 Old 05-02-2012, 09:31 AM
Smackrabbit's Avatar
Quoted: 31 Post(s)
Liked: 92
To properly use the white balance controls, you'd need a meter and software to read the grayscale from the screen and show which direction those controls need to go. Doing it by eye isn't recommended as you're just as likely to wind up setting them to be worse than better.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is online now
post #3 of 3 Old 05-02-2012, 09:32 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Only with calibrators !
anta1974 is offline
Reply Display Calibration
