Display Uniformity Correction (for a PC monitor)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-02-2012, 10:49 PM - Thread Starter
Tempest261's Avatar
Quoted: 13 Post(s)
Liked: 34
Hi everyone,
I am an amateur calibrator, and I have an X-rite i1 Display Pro (with PC monitor calibration software), and a Calman DIY license (for televisions), and I've ran into a new problem that I can't seem to solve:
There is a new "fad" for buying Korean-branded and targeted 27" IPS monitors. They have no OSD, a very low cost, and are using the same LG IPS panels that are sold to Dell, Apple, HP, etc. The catch is, they usually have a flaw or two. The one I bought is no exception: it's a beautiful display, and has zero dead/stuck pixels, but it has pretty poor uniformity. If I take a small white notepad window, and move it around the screen, I can easily see the color temperature of white change. The reference point that I calibrated against is a perfect white (to my eyes), but along the edge 1/3 portions of the screen, it's definitely warmer. I measured the different points with the included Xrite software, and verified what my eyes are seeing. Thankfully, the brightness uniformity is pretty decent, but I'd like to correct the color temperature uniformity (or lack thereof).
Is there any relatively inexpensive software package that can correct for PC display uniformity issues? This would obviously have to be a software solution, and would require an extensive calibration (from a dozen+ points on the monitor), but would work wonders on this monitor. I don't think CalPC has this feature, but if SpectraCal is listening, if they add it to a future release, I will gladly buy a license.
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Tempest261 is offline
post #2 of 5 Old 05-03-2012, 04:27 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
That sucks man!
I am no authority, so this is just a guess using my small amount of knowledge on the subject as a base.
I think the only way to fix uniformity issues is to buy a better display. Like under saturated primaries, there is nothing you can do.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 5 Old 05-03-2012, 04:34 AM - Thread Starter
Tempest261's Avatar
Quoted: 13 Post(s)
Liked: 34
Originally Posted by airscapes View Post
That sucks man!
Well I found that there are some software packages that exist, but most of them exist for the medical industry, and are therefore ~$500. I'd like to see something for the consumer market- assuming something doesn't already exist.
It's also not as bad as I make it sound. It's very hard to notice, unless you're looking for it. If I took a picture of it with a camera, for instance, I doubt anyone would be able to detect the problem. Definitely something that I could live with, but it would be very interesting (and worthwhile) to try to correct it.
post #4 of 5 Old 05-03-2012, 08:39 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Even the medical packages don't correct uniformity, at least from what I've seen. They just quantify it to see if your monitor is out of spec or in spec.
The only way to fix it is buy a different monitor.
sotti is offline
post #5 of 5 Old 05-03-2012, 09:02 AM
Smackrabbit's Avatar
Quoted: 120 Post(s)
Liked: 296
The uniformity differences, among others, are why the NEC PA271W sells for $1,200 and other monitors sell for half that. If you want it really uniform it just costs much more. The NEC is more uniform than any other monitor I reviewed, but it costs more than any other one as well.
Chris Heinonen
Staff Writer, The Wirecutter, a NY Times Company
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Secrets of Home Theater and High Fidelity, AnandTech.com, HDGuru.com and Electronic House
Smackrabbit is offline
Reply Display Calibration
