How power law gamma calibration can lead to crushed blacks - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #211 of 231 Old 12-03-2012, 04:15 AM
Light Illusion's Avatar
Quoted: 513 Post(s)
Liked: 817
In a calibration system where profiling is separate from calibration there is no reason for Gamma to affect Gamut...
The problem is when the two are interlinked, so that altering gamma causes a global change to the calibration - which it shouldn't.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is online now
post #212 of 231 Old 12-03-2012, 04:54 AM
Jeroen1000's Avatar
Quoted: 39 Post(s)
I had actually missed page 8 of this thread where there is an explanation. Except, judging from the explanation, gamma DOES affect the hue. Check out post #182 by Sotti. This going to sound either understandable or stupid:-):
Changing gamma does only not only change Y(luminance) for white, which we check by measuring the greyscale, but for all the colours (I found out you are British hehe).
Changing luminance is actually nothing more than altering the ratio of R, G and B at a certain point of stimulus (adding/removing green will have the biggest effect on Y).
The above tells me gamma will always affect gamut. Since I know you are a very clever person in the matter, either the above is wrong or I'm missing a crucial bit of information?
edit: I'm reading the previous page but it will take a few more reads to really get it...
My gear: Panasonic TH-42PF11EK pro plasma display + TX-P55VT60E -- Iscan Duo video processor -- i1 display 3 colorimeter -- i1 pro 2 spectrometer
Jeroen1000 is offline
post #213 of 231 Old 12-03-2012, 05:37 AM
stevekale's Avatar
Quoted: 374 Post(s)
Liked: 45
Originally Posted by Light Illusion View Post
We have done a lot of work with ICC's (CMM's), and have found time and again just how inaccurate they can be...
Let's face it, any calibration process that has a 'Use Black Point Compensation' as part of its options isn't really looking like an accurate calibration method.
Seriously, we have been called into facilities time and again to rescue them from issues caused by trying to use ICC profiles for accurate calibration.
For video? I wasn't aware that videos were capable of embedding an ICC profile and that there were CMMs capable of using them (yet). I understood video to be stuck in the intransigent world of hard coding calibration which of course is annoying if you regularly switch between SD and HD media (and your display can't adapt to the changing content). ICC profiling is very effective in graphics (non video) world. As for BPC, it makes immense sense to scale luminance for a difference in black point.
(Of course also we need to distinguish between calibration and profiling.)
Demand greater honesty and transparency in high-end audio
With Theta, Egglestonworks and Krell since 1998!
stevekale is offline
post #214 of 231 Old 12-03-2012, 06:36 AM
Quoted: 513 Post(s)
Liked: 817
Jerone, see my comment above your last post - if profiling is separated from calibration there is no interlinking.
With LightSpace you can do a profile and then set a Rec709 target with 2.2 Gamma, or 2.4 Gamma, and the changes in gamma will not alter the Gamut calibration...
Steve, Adobe attempted to force ICC calibration (and we do indeed understand profiling vs. calibration) on to their video users - it didn't work.
And there is no sense at all for 'Use Black Point Compensation' within an accurate calibration workflow.
Switching between colour spaces is very, very easy.
The professional video world does this all the time.
Steve
Steve Shaw
LIGHT ILLUSION
post #215 of 231 Old 12-03-2012, 08:26 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Steve
How do you transfer your profile to a TV's settings if there is no LUT box involved?
Also how do you implement BT.1886 in your software since it does indeed use the black point as part of formula.
Interesting that you condem black offset, yet the only approved standard for HDTV playback includes it.
http://www.itu.int/dms_pubrec/itu-r/rec/bt/R-REC-BT.1886-0-201103-I!!PDF-E.pdf
Adobe RGB also has many provisions for the fact that displays have non-zero black level
http://www.adobe.com/digitalimag/pdfs/AdobeRGB1998.pdf
sotti is offline
post #216 of 231 Old 12-03-2012, 08:32 AM
Quoted: 513 Post(s)
Liked: 817
Umm, we are ONLY interested in LUT based calibration... As is says on the website - turn off all the internal rubbish, as it does more harm than good.
We can and do implement ANY colour space as we will have profiled the display in advance... that's kind'a obvious, isn't it?
'Use Black Point Compensation' is not black offset... very, very different animals.
It is impossible to 'add' black to a display, so the calibration needs to be 'float' based. Again that has to be obvious, doesn't it?
Steve
Steve Shaw
LIGHT ILLUSION
post #217 of 231 Old 04-17-2013, 07:57 AM - Thread Starter
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
Originally Posted by Jeroen1000 View Post
sorry for kicking this up when the dust has settled. Why is it indeed, that "gamma" affects the gamut?
Not a direct answer (it's been covered in this thread already) but here are some statistics on what type of errors can be generated across the gamut when your assumption of source gamma does not match display gamma. I also threw in a color space mismatch (601 vs. 709) for comparison. These are measured values (2500 colors) on my display with dE calculated based on the assumptions in the legend.
zoyd is offline
post #218 of 231 Old 04-20-2013, 12:33 PM
ADU
ADU's Avatar
Quoted: 430 Post(s)
Liked: 703
^ Interesting.
The 601/709 mismatch is pretty small. I've often wondered if the difference between 601 and 709 would be big enough to catch in a simple visual color-bar decoder test.
I wonder what a Rec. 709 vs. Rec. 2020 (wide gamut) mismatch would look like btw? (Pretty substantial I'm guessin.)
ADU
ADU is offline
post #219 of 231 Old 04-21-2013, 05:52 AM - Thread Starter
zoyd's Avatar
Liked: 1064
I can see it in color bars when switching between 709/601 calibrated primaries but picking it out stand-alone is pretty tough.
zoyd is offline
post #220 of 231 Old 04-21-2013, 10:32 AM
HDTVChallenged's Avatar
Liked: 215
^ Interesting.
From my personal experience:
REC601 sources through a REC709 decoder is tolerable.
REC709 sources through a REC601 decoder will drive you completely nuts even on normal programming (blue is boosted significantly.)
Yes, you can detect it through a "simple" color decoder/filter test, if you know what to look for ... smile.gif
HDTVChallenged is offline
post #221 of 231 Old 04-21-2013, 03:31 PM
dr1394's Avatar
Quoted: 155 Post(s)
Liked: 79
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is offline
post #222 of 231 Old 04-21-2013, 08:09 PM
ADU
ADU's Avatar
Quoted: 430 Post(s)
Liked: 703
^ Nice. Thanks for posting those. They illustrate the difference quite well.
ADU
ADU is offline
post #223 of 231 Old 04-21-2013, 08:10 PM
ADU
ADU's Avatar
Quoted: 430 Post(s)
Liked: 703
Originally Posted by zoyd View Post
Very cool! Thanks for posting this zoyd.
This graphically illustrates why it can be so difficult to get the color on some wide gamut displays close to Rec. 709 spec.
ADU
ADU is offline
post #224 of 231 Old 06-19-2013, 01:25 PM
Koperfild's Avatar
Could anyone tell how does Calman 5 calculate gamma when non-zero black level is applied? It doesn't look like simple black offset (Vin = Vout^gamma + black lvl) because the value is somehow scaled across the dynamic range (for example 1% IRE target is raised by almost 100% value of the black level, while 99% IRE is almost not affected at all)... Is it a standard way of calculating gamma?
JimP likes this.
Koperfild is offline
post #225 of 231 Old 06-19-2013, 02:38 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
It depends on the gamma formula. Some (like BT.1886) use the black level as part of the input value for the function. For those that don't we do a simple compression of the range.
sotti is offline
post #226 of 231 Old 06-20-2013, 12:17 AM
Koperfild's Avatar
Thanks for your answer Joel. Is, what you do, a common procedure, or is it your own solution?
Poynton in his "Gamma Rehabilitation" doc. mentioned following equation: L= (V’ +ε)^gamma, where ε is black offset. On the internet more popular equation is Luminance = contrast * value^gamma + black level. None of them is similar to yours as far as I understand.
post #227 of 231 Old 06-20-2013, 09:34 AM
Liked: 215
Don't know what Joel's using, but in my spreadsheet I believe I used:
L = Lb + (Lw-Lb)* V^gamma
In other words, apply power law over the reduced range between your measured white and black levels then add the black level in as a linear offset.
BT.1886 does this much more intelligently (not to mention aggressively.)
Or you could just follow power law down as far as you can, and let your brightness control setup handle the compression near black.
There's probably a "right" answer somewhere in all of this, but the truth is probably that there's no way to know what method was used on the mastering/editing monitor, until you see something that looks really wrong ... like "black" holes in the back of peoples heads where there should be blondish hair (e.g.: "Black Swan".)
post #228 of 231 Old 06-20-2013, 11:03 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Exactly. Studio's aren't all conforming to any particular standard, which means that there is actually no right answer. Quite a few just run standard 2.2 with no offset for black. Some are starting to use BT.1886.
sotti is offline
post #229 of 231 Old 06-20-2013, 11:25 AM
Elix's Avatar
Quoted: 238 Post(s)
Liked: 104
I've read through the whole topic (quite a long time ago, actually) and have been conducting my own experiments on this for a while. Nobody seemed to ask some questions which seem quite obvious to me. When pursuing for ultimate shadow detail what level would you want to be able to see in the actual video content? Is it 1 or maybe 2 (on a 0-255 scale)? And when we say 'see' how distinctly that would be? Must we use this or that pattern to judge the visibility of low level signals? I believe that's practical questions.
A theoretical question will be: "Will every display calibrated to BT.1886 be able to distinctly reproduce these low level signals?".
Elix is offline
post #230 of 231 Old 06-20-2013, 10:15 PM
Liked: 215
Perhaps the reason that nobody asked that question is this: You should be able to see anything between 8 bit digital level 16 and 255 for video content. IOW: 17 to 254. By definition, black =16 and reference-white = 235. 236 through 254 is the overshoot (aka superwhite) range.
Yep ... assuming the display can actually pull off BT.1886.
post #231 of 231 Old 05-24-2015, 12:21 PM
fluxo's Avatar
Quoted: 419 Post(s)
Liked: 265
ITU/EBU recommends that the end-to-end gamma of the video chain should be between 1.1 - 1.2 so we have a clearly defined target. It's commonly stated that video RGB is encoded with an exponent of 1/2.22 but the full function is:
v'=4.5*v for v < 0.018
v'=1.099*v^(.45)-0.099 for v >= 0.018
So what we want our displays to do is invert the function above and then apply a modest power of between 1.1 - 1.2.
What do we do in practice? We feed the display a linear input of 10% steps and (if we have a 10pt gamma control) try to get a nice flat fit to the equation v=v'^(gamma=2.2, 2.3, etc.) This completely ignores the fact that the real video signals we will eventually watch are encoded using the equation above.
So what are the consequences of the simplified power law calibration approach?
This is a plot of the result of feeding a linear signal which has been encoded using the BT.709/601 transfer function into a display with a simple power law response.
Which gamma formula are you using for that plot, please?
This is my plot, for various exponents, based on a log-log gradient definition for point gamma:
By the way, you might find this interesting, if you have not already seen it:
http://downloads.bbc.co.uk/rd/pubs/w...les/WHP283.pdf
Thank you.
Eyleron and anta1974 like this.
fluxo is offline
Reply Display Calibration
