New to calibrating... w/o DVD/Blu-ray player... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-13-2012, 06:42 PM - Thread Starter
roach9's Avatar
I want to use the AVS 709 calibration tool, but I don't have any disc-reading capabilities.
Can I plug in my laptop via HDMI to my television and use the calibration tool, or will this not produce proper results?
I've read through the AVS 709 OP but can't find any information on whether I am out of luck or not...
Thank you all for the help! (PS , just bought a 47LK520)
roach9 is offline
post #2 of 9 Old 05-13-2012, 08:54 PM
PlasmaPZ80U's Avatar
Quoted: 1970 Post(s)
Liked: 565
What source(s) do you typically use/watch on you TV? You'll probably need a DVD or (preferably) a BD player to be able to properly use the AVS disc. Using the USB input is not a good idea neither is the laptop unless you only want to calibrate for that specific use only.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #3 of 9 Old 05-13-2012, 10:08 PM - Thread Starter
roach9's Avatar
Really appreciate the reply.
My sources include an HD box (from my cable provider) and a Patriot Box Office...
will either of these two things work? Particularly the PBO...
roach9 is offline
post #4 of 9 Old 05-13-2012, 11:34 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
If the patriot box office is your primary source for "reference" material then by all means grab the AVS709 mp4 files and use that as your source.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #5 of 9 Old 05-13-2012, 11:58 PM - Thread Starter
roach9's Avatar
How do you define reference material? Thank you for your help!
roach9 is offline
post #6 of 9 Old 05-14-2012, 12:48 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
What I mean by that is content that you know is mastered correctly.
You can never really be sure what is happening with cable and cable boxes so you can't be sure that a video clip on TBS will look like the same video clip on FOX. But a Blu-Ray or a mpeg-4 rip of a Blu-Ray should look the same everywhere. So by reference I mean something that you know would look correct on a correctly calibrated display (as oppose to an unknown thing, like whatever the nat geo channel is broadcasting).
Joel Barsotti
SpectraCal
sotti is offline
post #7 of 9 Old 05-14-2012, 02:06 PM
saturndude's Avatar
Several hundred discs (some editions of Avatar, Dances With Wolves, The Towering Inferno, Willow) are "THX certified". They have some test patterns (nothing to do with sound) you can use. I used Willow. Look in the "special features" menu.
(I just read that you don't have a DVD player -- but you have a laptop. Does it have a software DVD player?)
I don't know where I read about the THX test patterns, but I'm glad I did.
I think it helped me a lot.....
saturndude is offline
post #8 of 9 Old 05-14-2012, 02:11 PM
Liked: 565
those patterns are not always accurate and sometimes only work for watching that particular movie
post #9 of 9 Old 05-14-2012, 02:12 PM
Liked: 565
good idea, that should work for the OP
Reply Display Calibration
