spyder 4 tv hd. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-17-2012, 04:10 AM - Thread Starter
Scottthehat's Avatar
Hi has any one used it and if so what do you think of it.
Cheers.
sharp lcd 42"samsung ps59d550 plasma,onkyo 875/606,sherrwood 945 avr,sony md/cd/ps3,toshiba hd dvd/bluray,panasonic blu-ray,wharfdale front/center/15" sub+2 12",eltax liberty rears x2(7.1),jamo 12" fronts + rears,sky hd,teac td, spyder 4tvhd + chromapure calibration stuff. nikon d700/d300 + pro glas
Scottthehat is offline
post #2 of 4 Old 05-18-2012, 05:29 PM
lb750's Avatar
Cheers.
I used it on my Samsung UN55ES7500. It made a big improvement over the stock settings. You have to do the calibration with the TV in the standard mode. I then used the settings and applied them to the movie mode. I now like the picture better in movie mode instead of standard.
lb750 is offline
post #3 of 4 Old 05-18-2012, 06:42 PM
PlasmaPZ80U's Avatar
Quoted: 1960 Post(s)
Liked: 559
I don't think you can copy settings from one picture mode to another and expect that to provide the same result as calibrating in movie mode to begin with.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #4 of 4 Old 05-19-2012, 12:47 PM
lb750's Avatar
You are probably right but when I tried to calibrate in movie mode, the screen would go black when I was trying to calibrate birghtness
settings below 19. Not sure why this happens.
lb750 is offline
Reply Display Calibration
