CNET and televisioninfo Calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 05-17-2012, 12:36 PM - Thread Starter
electroFan's Avatar
CNET webpage is doing tv reviews with calibration reports. I read that they are calibrating the TVs light output (Y to 100 IRE) approximately 130 footlamberts. This is an outrage, right?. The findings of the review will be erroneous, right? What do you think?
electroFan is offline
post #2 of 29 Old 05-17-2012, 12:39 PM
GeorgeAB's Avatar
Location: Denver, CO metro area, www.cinemaquestinc.com
Quoted: 152 Post(s)
Liked: 258
Please provide a more specific link to such statements.
GeorgeAB is offline
post #3 of 29 Old 05-17-2012, 12:52 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
It's probably cd/m^2 and not fL
sotti is offline
post #4 of 29 Old 05-17-2012, 12:58 PM - Thread Starter
electroFan's Avatar
I'm confused
CNET first explained to me that the luminances are measured in foot lamberts. CNET Depues explained to me that the luminances are measured in cd/m2.
For example the last review of the LG LM9600 explains:
Black luminance: 0.0198
CNET 0.0198 qualifies as an average value. If the value is measured in cd/m2 then it is a very good value.
Furthermore CNET says:
To 100 IRE Luminance pre-calibration: 145.1
To 100 IRE Luminance post-calibration :: 134.3
It's strange pre-calibration luminance of 145.1 cd/m2 is not it?
post #5 of 29 Old 05-17-2012, 01:01 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
I'm confused
Not really, you can typically lose a bit of luminance calibrating. Typically you turn down contrast to prevent clipping. In doing that you'll give up a bit of luminance. Also moving the white point from 13000K or whatever ships from the factory to D65 may also cause the luminance to be a little lower.
sotti is offline
post #6 of 29 Old 05-17-2012, 02:04 PM
PlasmaPZ80U's Avatar
Quoted: 2306 Post(s)
Liked: 708
I'm confused
the CalMAN reports are in cd/m^2, that's just the way reporting works in CalMANv4
the (post-cal) target fL CNET uses for all displays' peak white is 40 fL
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #7 of 29 Old 05-17-2012, 02:09 PM - Thread Starter
electroFan's Avatar
I think CNET indicates the luminance at 0 IRE in footlamberts (0.0198 ftL ) and then CNET indicates the luminance at 100 IRE in cd/m2 (145.1 cd/m2).
Is this correct?
post #8 of 29 Old 05-17-2012, 02:28 PM
Liked: 708
Is this correct?
yes, CNET uses fL in their reviews but the CalMAN reports are limited to cd/m^2 only (by design)
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #9 of 29 Old 05-17-2012, 02:32 PM - Thread Starter
electroFan's Avatar
This creates confusion, right?.
CNET should use the same unit of measurement to measure the luminance at 0 IRE and 100 IRE is not it?
post #10 of 29 Old 05-17-2012, 02:35 PM
Liked: 708
in the report it does (cd/m^2 only for all "Y" values)
but the number in the geek box is in fL
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #11 of 29 Old 05-17-2012, 02:45 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
The conversion back and for is 3.43 cd/m^2 to 1 fL.
So 0.0198 in fL is .0679 cd/m^2
A value of 134 cd/m^2 is 39 fL.
Gust to ballpark it I remember it's about 3 1/3 to one.
sotti is offline
post #12 of 29 Old 05-17-2012, 09:40 PM - Thread Starter
electroFan's Avatar
Now I am reading the calibratión of the webpage televisióninfo about LM9600 and I see thay they have calibraed tv for light output (peak white) of 436.95 cd/m2.
What is your opinnion about it? Should not they have calibrated the TV for a light output of 30-40 ftl?
Then all their conclusions are wrong or no?
post #13 of 29 Old 05-18-2012, 12:09 PM
Liked: 708
IMO that site doesn't know the first thing about calibration
they set backlight to 100% and used standard mode instead of the THX or ISF Expert modes
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #14 of 29 Old 05-19-2012, 02:07 AM
fallengt's Avatar
Uh.. I think that charts just to show highest contrast of those TVs, that's why they used "Peak" white ( backlight and contrast set to 100%). It isn't calibration.
fallengt is offline
post #15 of 29 Old 05-19-2012, 02:42 AM - Thread Starter
electroFan's Avatar
Televisioninfo say in "How we test tvs"
Peak white:
To measure the brightest white the TV can achieve, we set the display to show a small area of white (about 4% of the screen) at the center of the screen and measure the luminance in candelas per square meter with a CS-200 ChromaMeter set for a one degree acceptance angle. We do this after calibrating the HDTV as described above. Our score is based on how bright the white is after calibration; the brighter the white, the higher the score.
post #16 of 29 Old 05-19-2012, 04:57 AM
fallengt's Avatar
Yea? they didn't say it's the ideal condition to watch TV.It's just how they test and to score the white level and contrast.
The post-calibration results is meaningless for most people who don't have calibration tools (or don't want to hire ISF calibrators). That's why pre-calibration result is more important in a review.
fallengt is offline
post #17 of 29 Old 05-19-2012, 05:29 AM - Thread Starter
electroFan's Avatar
They say bright white after calibration on LG LM9600 is 436 cd/m2
This is outrageous and it undermines the credibility of the review
All pages written reviews score tv on black level and contrast post-calibration
post #18 of 29 Old 05-19-2012, 05:57 AM
fallengt's Avatar
Well, here is the ideal ... You can do peak white reading without calibration but the white may have some color tint and balance white level also change peak luminance thus result will be differents from these test methods. You can't say a blue tint white TV which has higher peak white is better than a zero color-tint white TV which has lower luminance.
What they want to achieve is to read "PEAK" white(without any tint - 100% RGB balance). By this way, the results from other TVs can be comparable from those charts.
I'm done here
fallengt is offline
post #19 of 29 Old 05-21-2012, 08:44 AM - Thread Starter
electroFan's Avatar
Calibration of televisioninfo for Samsung ES8000
Contrast: maximun (100)
Backlight: Maximun (20)
Output light: 351 cd/m2
What do you think?
post #20 of 29 Old 05-21-2012, 10:38 AM - Thread Starter
electroFan's Avatar
CNET TV's always calibrated dynamic contrast on, Is not this a mistake?
post #21 of 29 Old 05-21-2012, 10:41 AM
Liked: 708
they don't; show me some proof to back up your claims
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #22 of 29 Old 05-21-2012, 10:42 AM
Liked: 708
What do you think?
don't use that site; they don't know what they're doing
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #23 of 29 Old 05-21-2012, 10:49 AM - Thread Starter
electroFan's Avatar
LG LM6700 LED Local Dimming: High
Sony HX850 LED Dynamic Control: Standard
LG LM9600 LED Local Dimming: Medium
Sony HX929 LED Dynamic Control: Standard
post #24 of 29 Old 05-21-2012, 11:05 AM
ElectronicTonic's Avatar
Quoted: 65 Post(s)
Liked: 106
Non of those have dynamic CONTRAST on. Local dimming, and dynamic contrast, are two different things. All those links are backlight controls, at least the ones you're referring to.
ElectronicTonic is offline
post #25 of 29 Old 05-21-2012, 11:20 AM - Thread Starter
electroFan's Avatar
Local dimming ¿should not be turned off? Is it proper led dynamic control this on?
post #26 of 29 Old 05-21-2012, 11:40 AM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Calibrate with it turned off.
When you view content, off or on, your choice.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #27 of 29 Old 11-02-2012, 01:49 PM
digimat's Avatar
Quoted: 73 Post(s)
Liked: 222
They clearly state these settings on post calibration... and it's proof in there video review.
They claim the LG7600 has deep black levels... this would have only been the case if local dimming was engaged.
digimat is offline
post #28 of 29 Old 11-03-2012, 12:11 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
In any case, are you sure you can trust a source (CNet in this case) that uses "IRE" when referring to digital video? There is no such thing as IRE in digital video. IRE is an analog video specification that determines how bright the image is compared to the analog input voltage. Digital video doesn't use analog voltages to determine brightness. In digital video, "% white" is accurate and correct. IRE does not exist for digital video and does not mean the same thing as % white... it CAN mean the same thing as % white when referring to analog video, but it MIGHT NOT be the same thing as % white when referring to analog video... it all depends on how the video display is setup.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #29 of 29 Old 11-05-2012, 03:12 PM
digimat's Avatar
Quoted: 73 Post(s)
Liked: 222
I agree, CNET seems to do some odd things when it comes to testing. Also stating that the LG7600 had good black levels while the ES8000 did not, makes zero sense.
What would you recommend as a quality source for reviews?
digimat is offline
Reply Display Calibration
