Sharpness pattern - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ConnecTEDDD
  • 2 Post By Bounkass
  • 2 Post By xvfx
  • 1 Post By ZKACAL
  • 1 Post By Bounkass
post #1 of 22 Old 05-18-2012, 10:15 AM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
Does any one know a good pattern for sharpness calibration? I found Avs 709 sharpness/overscan to be impractical to use.
kanti123 is offline
post #2 of 22 Old 05-18-2012, 12:01 PM
Plasma54321's Avatar
I agree the lined patterns seem to be very ambiguous WRT halos or softness judgment call. Even when looking very closely and carefully to a pattern it is difficult. Also, the acceptable range seems quite large or variable.
To me it seems like a vertical swept sinusiodal signal starting at mid frequencies and going to the very highest resolution limits may be easier to view the effects of the sharpness control. In other words the pattern should be a even tone of gray (black to white). If sharpness control is doing anything negative there should be relative brightness shift in the pattern. So, adjust until pattern has uneven brightness then adjust back down until the pattern is an even gray tone across all frequencies.
This type of pattern is on the THX Optimizer (and others) as part of the Overall Check with color bars. However, it is very small. In addition I don't know what is the frequency upper limit.
Plasma54321 is offline
post #3 of 22 Old 05-18-2012, 12:05 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 41 Post(s)
Liked: 144
Greetings
Spears and Munsil has a good one ... so does DVE and Disney WOW too.
You would want a pattern that have a medium gray background and black lines on it ... preferably running up down and left/right
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #4 of 22 Old 05-18-2012, 01:20 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
What type of display is it?
It has been found that using the brightness pattern of the AVS disk (first one all dark flashing bars) after brightness is set, works well on some display types. Turn off all lights and get close to the set, turn up the sharpness and watch the pattern for white vertical lines where the flashing bars would be below 16 or if you set clips btb right at 16-17. If they show up, turn sharpness down till the go away. It has worked for me on LCD and Plasma. This side effect was reported by anther AVS member in another sharpness thread.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 22 Old 05-18-2012, 01:41 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Thank you very match!
anta1974 is offline
post #6 of 22 Old 05-18-2012, 02:50 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
IMO the best sharpness pattern is the disney wow disc.
1forsnow is offline
post #7 of 22 Old 05-18-2012, 05:52 PM - Thread Starter
kanti123's Avatar
Quoted: 62 Post(s)
Liked: 46
It's LED LCD display, Samsung UN55D7000 I tried to use the black level pattern to adjust my sharpness. My sharpness is currently at 4 instead of 12. I put on DVE bluray disc to calibrate my sharpness. Still hard to distinguish the different between artificial noise and such. Unless I turn my Sharpness to like 50 which is way to high.
kanti123 is offline
post #8 of 22 Old 02-16-2014, 11:39 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
Which sharpness pattern does Scott Wilkinson and Robert Heron use in the "Home Theater Geeks 175" episode when they calibrate Leo Laporte's OLED. That one seems straightforward.
ZKACAL is offline
post #9 of 22 Old 02-17-2014, 02:34 AM
ConnecTEDDD's Avatar
Quoted: 1730 Post(s)
Liked: 2130
* Scaled Picturea from Actual 1920x1080 pixel sized Patterns.
Hello, this Advanced Sharpness Pattern is available inside the Ted's LightSpace CMS Calibration Blu-Ray Disk among with other 150 Color Reproduction Patterns.
This Advanced Sharpness Pattern is not limited to typical Black/Gray/White Background that all current calibration disks are using but at 4-Step of 7-Color Amplitude Background... wink.gif
Better View - Part of the Advanced Sharpness Pattern
This Sharpness pattern is a real challenge for any display, it's will uncloack problems of yur current sharpness control setting or from other enabled enhancements that were not visible before.
You can use it to verify your current sharpness setting value that you have set using a pattern generator or other calibration disk pattern since all other sharpness patterns available are based at grayscale lines/backgrounds only.
These multicolored backgrounds and shapes/lines conbination maybe some times will make you add 1 or reduce by -1 or more of you sharpness slider setting that you have already set based on other classic grayscale based sharpness patterns.
buzzard767 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #10 of 22 Old 02-17-2014, 06:27 AM
Bounkass's Avatar
I personally like the following:
Too sharp and the TV will add information/white lines around the black lines. Too little sharpness and the lines will look out of focus.
PlasmaPZ80U and anta1974 like this.
Bounkass is offline
post #11 of 22 Old 02-17-2014, 06:42 AM
Rayjr's Avatar
Quoted: 187 Post(s)
Liked: 225
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
They are using the Sharpness pattern from the AV Foundry Video Forge Signal Generator.
Hope this helps.
RayJr
Rayjr is offline
post #12 of 22 Old 02-17-2014, 06:49 AM
jdoostil's Avatar
As long as overscan is off, the sharpness pattern displayed on almost every Samsung panel I can think of should direct you to have the sharpness at 0. If the overscan is on, the sharpness pattern will always look distorted. Check a multiburst or overscan pattern as well
ISF certified in 2008
ISF Level II certified in 2010
ISF instructor certified in 2012
ISF International Trainer since 2014
ISFJasonD65@gmail.com
Serving Florida
jdoostil is offline
post #13 of 22 Old 02-17-2014, 06:15 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
Is this from Spears and Munsil?
ZKACAL is offline
post #14 of 22 Old 02-17-2014, 06:18 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
Hope this helps.
RayJr
Do pattern generators come with their own patterns already or do you have to upload your own set of patterns? Which company or from what disk was their sharpness pattern brought up from?
ZKACAL is offline
post #15 of 22 Old 02-17-2014, 06:22 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
In Home Theater Geeks 175, they went with 5 for the Samsung OLED.
ZKACAL is offline
post #16 of 22 Old 02-17-2014, 06:46 PM
Rayjr's Avatar
Quoted: 187 Post(s)
Liked: 225
Pattern Generators have there own patterns built into them..but as SpectraCal built the video forge...I think they also offer there patterns on a USB stick..look HERE I think this has the same patterns as the video forge.
Hope this helps
RayJr
Rayjr is offline
post #17 of 22 Old 02-18-2014, 01:09 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
1024 768 tv here can get pretty blurry on bright screens(high abl).I m using a setting of 50.It adds garbage but it unblurs it.I could go much higher too unblur it.
This is for cable tv watching.
Vic12345 is offline
post #18 of 22 Old 02-18-2014, 06:33 AM
Bounkass's Avatar
I have no idea I just googled for it a while back.
Bounkass is offline
post #19 of 22 Old 02-18-2014, 06:53 AM
Liked: 2130
It's from Spears & Munsil High-Definition Benchmark Vol. 1
Bounkass likes this.
post #20 of 22 Old 02-18-2014, 02:05 PM
xvfx's Avatar
Quoted: 410 Post(s)
Liked: 242
This is a good pattern. I could never find the right setting for Sky HD 1080i and it turns out I was one click too high, versus AVS709 and Mascior's disc. Both HD and SD look lovely and smooth now.
PlasmaPZ80U and Bounkass like this.
xvfx is offline
post #21 of 22 Old 02-18-2014, 02:35 PM
ZKACAL's Avatar
Quoted: 35 Post(s)
Liked: 25
I think I'm going with S & M too.
ZKACAL is offline
post #22 of 22 Old 02-19-2014, 07:06 AM
Bounkass's Avatar
Yeah, I like it too. Plain and simple. No unnecessary features.
PlasmaPZ80U likes this.
Bounkass is offline
Reply Display Calibration
