Iscan Duo secondary output - AVS Forum | Home Theater Discussions And Reviews
Old 05-19-2012, 08:06 PM - Thread Starter
ETS1979's Avatar
I have recently purchased an Iscan Duo. Is there a way to set up the second output with a separate calibration for simultaneous display, or at least a way to turn off the primary calibaration sent to the second display? If so I have not been able to figure it out.
ETS1979 is offline
Old 05-20-2012, 12:43 AM
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
With the Duo you have 2 profiles, Night and Day, for each output.
avsform1 is offline
Old 05-20-2012, 02:23 PM - Thread Starter
ETS1979's Avatar
How do I seperate the two output setups? Everything I have tried to change on one also shows up on the other. Both the TVs I have connected are individually recognized by the Duo, but other than that I see no difference. How do I set up one without affecting the other during simultaneous operation?
ETS1979 is offline
Old 05-20-2012, 02:35 PM
ElectronicTonic's Avatar
Quoted: 64 Post(s)
Liked: 103
I have mine set to output to both simultaneously, but I manually select which output I'm watching. (HDMI 1, or HDMI 2)
You should be able to tell a difference, if you calibrated each output. The bad thing is you can't have them both selected at the same time, that I know of.
ElectronicTonic is offline
Old 05-20-2012, 02:47 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I have two projectors connected and both active at the same time. Both have separate day and night modes. So not sure why your calibration is sent to the second display.
Although I don't have both turned on at the same time. Maybe thats the difference.
Ron
Ronomy is offline
