Deep Color Test Pattern - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 03-09-2013, 01:54 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
does the PS3 output YCbCr 4:4:4 or YCbCr 4:2:2 when playing BD movies?
and I know I asked this before, but does it matter whether the Deep Color setting is on 'Automatic' or 'Off'?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #32 of 35 Old 03-10-2013, 02:48 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
It plays the mode you set it to play as I recall... haven't looked at my PS3's menu in a long time though, but I'm pretty sure there were 4:2:2 and 4:4:4 options... though if you select 4:4:4 you'll get 8 bits and if you select 4:2:2 you'll get 12 bits by default unless you change the bit depth somewhere else... this is a little known or understood factoid that Jim Peterson (Lumagen) has posted in at least 1 thread here.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #33 of 35 Old 03-10-2013, 03:53 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Ps3 doesnt have the option to choose between 4.2.2 and 4.4.4, it does 4.4.4
Wouter73 is offline
post #34 of 35 Old 03-10-2013, 09:04 PM
ElectronicTonic's Avatar
Quoted: 63 Post(s)
Liked: 103
This is true.
I've verified this with my receiver and a Lumagen.
ElectronicTonic is offline
post #35 of 35 Old 03-10-2013, 10:38 PM
Liked: 562
thanks, I asked because there is no choice between 4:4:4 and 4:2:2 and it's not labeled as either
Reply Display Calibration
