Luminance & Grayscale - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-22-2012, 10:38 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 61
Is there a desired average percentage of luminance between grayscale steps? Would too great a jump in luminance between steps cause posterization?
I think I'm seeing a hint of posterization on some sources but my grayscale looks pretty good across the board. I'm trying to dial it in and I thought if there were some numbers I could use as a reference it would be much easier.
Mike
wmwilker is online now
post #2 of 7 Old 05-22-2012, 11:04 AM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
yes, and its called gamma and it's also affected by the dynamic range of the display
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #3 of 7 Old 05-22-2012, 11:10 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
There are many different formulas that seek to quantify what qualifies as a noticeable difference between colors. JND is what's used in the medical field and it has a pretty elaborate formula to determine the threshold of the next step from the previous step based on the luminance level.
But the gamut saturation level are closely connected to your gamma. So you can't really modify the step sizes without also changing your gamut saturation.
In the end all you can really do is choose an appropriate gamma target and luminance target. After that it's up to the source to minimize banding/posterization. All these streaming/on-demand low bandwidth source will frequently show posterization because it's encoded in the content.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 7 Old 05-22-2012, 11:11 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 61
Thanks, even though I feel stupid about the question.
If grayscale and gamma are virtually flat why would I have the hint of posterization? It is a little more obvious in cable source than in BR but it is still there.
Mike
post #5 of 7 Old 05-22-2012, 11:19 AM
Liked: 559
http://www.spearsandmunsil.com/artic...stcontrol.html
http://www.spearsandmunsil.com/artic...epatterns.html
These articles talk a bit about banding/posterization/contouring with respect to the brightness and contrast controls. Banding can also result from multi-point grayscale controls (like 10 or 20 point grayscale controls) and CMS controls. Other times your TV has it from the very beginning and you can't fix it or perhaps even reduce it (though you want try to minimize it as much as possible anyway).
post #6 of 7 Old 05-22-2012, 11:24 AM
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
Some controls just aren't implemented well and can only be adjusted so much before posterization kicks in, and some can be adjusted as much as you want with no issue. For example, on the JVC X30 this year, the gamma presets all worked great, but if I used the gamma fine tuning, posterization set in as soon as I adjusted it off the defaults. I've seen the same behavior on other projectors as well, so it's not a JVC issue only.
Try setting up a second memory with no adjustments done and see if you get the posterization or not. If you don't, then you can start to copy settings from the other preset, one at a time, starting with the basic ones first, until you can see if it sets in or not. Slow and tedious, but you could figure out what is causing it.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
post #7 of 7 Old 05-22-2012, 11:32 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 61
Thanks guys. That will give me something to work on for the next few days. I'll let you know how it works out.
Mike
Reply Display Calibration
