VT50 Calibration - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 184 Old 08-18-2012, 01:51 PM
rahzel's Avatar
Liked: 148
Agreed. I don't really follow the recommendations but set it to a level that's comfortable in my viewing environment. I set my 55LH90 to 40fL but find that 35fL is more than enough for my 60ST50 (ST50 replaced my LH90 in my HT room/basement).
rahzel is offline
post #92 of 184 Old 08-19-2012, 09:48 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Hi, today I calibrated my 65vt50 europe model for the first time. Im using chromapure with an i1 display 3 and an i1 pro 2 spectro. It's amazing how relatively easily it is to get grayscale, gamma and color correct. What really bugs me though is the capped brightness in the pro isf mode. I have my contrast at max now, but it is still dimm. Can someone tell me how the pro's do this? Also, I could do whitebalance in the THX mode through the service menu, but on my display gamma and color are really off. Why did they cap the brightness anyway? Whats the point? To make sure the THX has more pop?
Wouter73 is offline
post #93 of 184 Old 08-23-2012, 01:07 PM
Quoted: 1704 Post(s)
Liked: 731
How many of you guys are using a powered usb hub on your laptops in order to maintain correct voltage to your colormeter or spectrophotometer?
Doing some research, I find that the i1Pro and the i1Pro2 both are power hunger and laptops are notorious for not have correct power to their usb ports.
I've ordered a powered usb hub and look forward to making comparisons. It only shipped today so it's going to be a few days before I have it.
A related question....those who are not using a powered usb hub and are using a laptop, does blue saturation cease increasing in your software charts even though you're increasing blue saturation?
JimP is offline
post #94 of 184 Old 08-23-2012, 01:48 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 61
I use one (Plugable from Amazon) but I use it for convenience. I have calibrated without it and I haven't noticed any problems.
Mike
wmwilker is offline
post #95 of 184 Old 08-25-2012, 08:51 AM
Carl_Ballard's Avatar
Have the 3D settings been posted?
Carl_Ballard is offline
post #96 of 184 Old 08-25-2012, 12:13 PM
GeorgeAB's Avatar
Location: Denver, CO metro area, www.cinemaquestinc.com
Quoted: 152 Post(s)
Liked: 260
You are more likely to find them in the display owner's section of the forum. This "sticky" thread explains why: http://www.avsforum.com/avs-vb/showthread.php?t=1055906 .
GeorgeAB is offline
post #97 of 184 Old 08-25-2012, 12:29 PM
sillysally's Avatar
Quoted: 1015 Post(s)
Liked: 952
Same findings here, also.
ss
"Don't worry be happy"
For Sale Lumagen Radiance Pro 4440/2, see link for details
http://www.avsforum.com/forum/210-vi...l#post54911046
sillysally is offline
post #98 of 184 Old 08-25-2012, 01:07 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Hi,
I have something in my calibration of my VT50 I dont get. When I do my whitebalance, my grayscale is very good from 20 to 100 %. However, when I measure white as the first pattern for my color gamut, white has a de of more than 5. Even after repeated measurements, it stays there, it does not drift. I use exactly the same meter, right after I do whitebalance. How can this exist at the same time, a near perfect white that is totally off as soon as I do color gamut?
Wouter Panasonic 2308012.pdf 2401k .pdf file
Wouter73 is offline
post #99 of 184 Old 08-25-2012, 01:26 PM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
Originally Posted by Wouter73 View Post
Hi,
if your grayscale readings include 70% and 80% stim but the gamut white is 75% that means the VT50 is not tracking grayscale linearly between 70% and 80% (and possibly elsewhere too)
to avoid this problem, use two point grayscale to get things close and then finish with 10-pt grayscale as opposed to using 10-pt only
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #100 of 184 Old 08-25-2012, 02:15 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Ok, thanks, that at least clears up why it happens. I did however do exactly as you said, first two point then 10 point. A well, it'll take a while for me to understand my new tv I guess smile.gif
Wouter73 is offline
post #101 of 184 Old 08-26-2012, 09:58 AM
Got it. Thanks.
post #102 of 184 Old 08-29-2012, 12:33 PM
cpluse's Avatar
I look to get the iDisplay Pro and waiting on Cal 5. But they have a discount this week. Do i really need the CalMAN DPG-2000 Digital Pattern Generator?
What was out there before the CalMAN DPG-2000 Digital Pattern Generator?
I'm only using this for my home use. Maybe also calibrate my imac to while im at it.
cpluse is offline
post #103 of 184 Old 11-01-2012, 11:01 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Hi, i've read somewhere that it is possible to do wb for THX in the service menu. However, when I go to the wb section, I can select the "normal" presets like standard and cinema, but THX is nowere to be found. Am I misunderstanding something?
Wouter73 is offline
post #104 of 184 Old 11-02-2012, 12:05 AM
WiFi-Spy's Avatar
Quoted: 521 Post(s)
Liked: 965
The WB settings in the SM are tied to the color temp presets (cool, warm ect) and are not tied to the specific display modes.
Tyler Pruitt - Technical Liaison - CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #105 of 184 Old 11-02-2012, 02:28 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Ok thx. I am wondering though, I do have a few presets available in the sm, that visibly change the picture when i change them. How can I adjust wb for THX mode then? Do I need to go n and out of the sm every time to check it?
This isnwhat my sm looks like, is it the same n my EU model as it is n the US model?
http://s1298.photobucket.com/albums/ag59/henkdenegende/?action=view¤t=CC1721D9-E4F7-4940-B15D-D9F6353EBA73-1959-000001D4F8AE6AB7_zps2522073c.jpg&evt=user_media_share
Wouter73 is offline
post #106 of 184 Old 11-02-2012, 03:20 AM
H Stevens's Avatar
Quoted: 21 Post(s)
This is interesting. I had my set professionally calibrated and the calibrator used "THX Cinema" picture mode, Warm 2 and made the majority of adjustments in the service menu under "Cinema". If I understand your statement correctly, when I switch to "Custom" picture mode, none of the changes that he made are visible. Correct? Or are you saying that whenever the setting of Warm 2 is used, the calibrator's settings are in effect(despite the picture mode)? So, if I put the TV in "Custom", "Warm 2" the calibrator's adjustments are utilized?
H Stevens is online now
post #107 of 184 Old 11-06-2012, 11:30 AM
maygit's Avatar
Does anyone have any suggestions or calibration settings for "Game Mode"? THX looks great, but there's noticeable screen lag. Game mode still induces some lag, but it's much more tolerable; however, it's not calibrated and looks too vivid. I know this setting is limited for calibration controls, so if anyone could maybe touch on changes they made to the basics (brightness, contrast, color, tint) so i can have a general idea where to put my settings, I would appreciate it. Right now i'm at contrast 100, brightnes 64, color 49, tint +1, sharpness 0, everything else off, black level light. Looks better than default, but still not where i'd like it.
maygit is offline
post #108 of 184 Old 11-09-2012, 05:34 PM
turboman123's Avatar
Quoted: 34 Post(s)
Liked: 26
Hi,
Goedendag Wouter
Did you find out your problem?
If not, can you run the greyscale in Chromapure with 5% steps and show the results. You have to use the "save greyscale image" because in the reports, only the 10% steps are shown.
What patterns are you using for greyscale, and for Color Management?
turboman123 is offline
post #109 of 184 Old 11-09-2012, 05:58 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Originally Posted by turboman123 View Post
Goedendag Wouter
Something was changed. The before has white at 312, 330, 49.6 FtL and the after 319, 339, 41.3. Both the CIE coordinates and the luminance have changed considerably and the "after" coordinates are way off. What happened there?
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #110 of 184 Old 11-10-2012, 02:51 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
That is because I used 75% patterns for color gamut, and therefore started with 75% white (grey).
So the problem was the grayscale tracking. Somehow this problem has not been an issue annymore. Instead, I am extremely annoyed by the light-output cap in the ISF modes, so now I have a perfect grayscale, colorgamut and gamma but with way too dimm a picture in bright scenes in ISF, or a fairly accurate (two point in SM) grayscale in THX mode, but with crappy gamut and gamma. Panasonic flagship and best PQ tv of 2012....pah, might be true stil, but it's an annoying set to me, being an amateur calibrater. In the proces of trying to convince the wife that after paying 3000 euro for a tv, it's perfectly logical and okay to pay another 1500 euro for a lumagen mini3d :P
Wouter73 is offline
post #111 of 184 Old 11-10-2012, 05:44 AM
Liked: 731
I've been using Calman 5 for the last few days (evaluation licence) and notice that they take the approach of adjusting RGB together for your grayscale points to get your gamma lined up whereas with Chromapure and Controlcal, I've used the gamma adjustments.
Has anyone found one method to be any better than the other?
JimP is offline
post #112 of 184 Old 11-10-2012, 05:51 AM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
Think that ftl cap is only on the Euro models ?
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #113 of 184 Old 11-10-2012, 07:30 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
I think so, I know only for sure that we do not have a "panel brightness" setting.
Wouter73 is offline
post #114 of 184 Old 11-10-2012, 08:16 AM
turbe's Avatar
Liked: 97
Jim, use all of the 10pt controls, both 10pt W/B RGBs and 10pt Gamma when/where needed - this doesn't matter what calibration software you are using with ControlCAL. If you were just using 10pt Gamma (Luminance) controls (never adjusting 10pt RGB), that is not correct.
If you are posting about raising / lowing all three 10pt W/B RGB equally for gamma, it could be done but I'd try to balance it between the 10pt W/B and Gamma (Luminance) Controls, not adjusting G and avoiding extreme adjustments.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #115 of 184 Old 11-10-2012, 09:15 AM
buzzard767's Avatar
Liked: 2439
Agreed, the 10p gamma controls work exceptionally well. Do the 2 and 10p GS and then adjust the 10p gamma. Recheck. Done.
Buzz
post #116 of 184 Old 11-10-2012, 10:42 AM
Liked: 731
Thanks Turbe and Buz.
JimP is offline
post #117 of 184 Old 11-10-2012, 09:01 PM
sillysally's Avatar
Liked: 952
Yes that's correct, but when are you doing your primary secondary CMS, if you do your CMS after your GS/Gamma I would think you would want to recheck the same once done with the CMS.
Of-course you can also not use the 10 point gamma at all. I got very use to not using the 10 point Gamma controls at all with my Kuro 141, because they were very problematic.
Anyway as you can see with my ISF mode calibration report, I set my Gamma target to 2.2 and ended up with a Gamma of 2.2 along with all the numbers/charts being very close to ideal.
But all this becomes a moot point when you start to play with the 3D LUT 125 point cube and a 21 point GS using a Lumagen Mini 3D for both color patterns and settings. Once you get use to using this type of calibration/software and your meters and display profiling, I would think you understand why I use the phrase "moot point".
ss
post #118 of 184 Old 11-10-2012, 10:02 PM
Liked: 731
SS
Any problems in Calman's CMS module in getting blue saturation within a dE of 3? It reads low and any amount of adjusting doesn't seem to improve it.
It's acting as if it's getting a saturation pattern at 75% but trying to apply measurements at 100%...but just for blue.
JimP is offline
post #119 of 184 Old 11-10-2012, 10:44 PM
sillysally's Avatar
Liked: 952
SS
Yes imo blue hue is the most problematic setting to get right (ideal), saturation not as hard but still not easy. However it is possible to get both within dE of 3.
The good news is Blue is the least critical primary to get right, so a dE of close to 3 is just fine, Red for flesh tones and Green for foliage/lum/gamma more important.
Anyway imo that's is one of the big pluses for doing a 3D LUT 125 point cube, getting the Blue tones over a large range of Blue close to being right. iow no blue tint on teeth in a scene using a blue filter, things like that. Drove me nuts when calibrating my Kuro 141.
btw in your case if you ever want to do the 3D cube, you may get away with buying a ee color cube that is much cheaper than the Mini 3D and use your pattern generator. Buzz would know more about how well the color cube works, I think he has one.
ss
post #120 of 184 Old 11-11-2012, 02:19 AM
Quoted: 34 Post(s)
Liked: 26
Goedemiddag Wouter,
From this I understand that peak white in THX mode is acceptable for you? What peak white level do you measure in THX mode. If that peak white is acceptable for you, for what kind of environment: dark room, half dimmed, daylight?
Reply Display Calibration
