VT50 Calibration - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 184 Old 06-21-2013, 12:55 PM
cadett's Avatar
Quoted: 37 Post(s)
Liked: 98
Speaking of peak white & luminance, I typically use a 2% windowed pattern & based up on my room, I set my set to 35fl using that pattern. Is this the practical way of setting your desired peak white output?
cadett is offline
post #182 of 184 Old 06-21-2013, 11:41 PM
rahzel's Avatar
Liked: 148
I use the same patterns that I use for calibration. Not much use in knowing your peak luminance using tiny windows.
rahzel is offline
post #183 of 184 Old 06-22-2013, 04:10 AM
Quoted: 1394 Post(s)
Liked: 588
As long as you're comfortable with it being that bright/dim for your room, its as good a way as any. Some will say that with a 10% window, cave like conditions would be somewhere between 30 and 35 ftl. Then you have to make the conversion for 2% windows.
A while back, I asked if there was a standard way of measuring peak white such as using a certain size and type of pattern.
Mostly I got that there was no standard way of doing it.
Where this gets to be a problem is when one person says that they're getting 45 ftl and another says that they're getting 35 ftl and they both are seeing the exact same thing but using different size patterns.
JimP is offline
post #184 of 184 Old 06-22-2013, 06:39 AM
cadett's Avatar
Quoted: 37 Post(s)
Liked: 98
Thanks! That's exactly what I was thinking.
cadett is offline
Reply Display Calibration
