Tc-p60st30 calibration issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-26-2012, 01:34 AM - Thread Starter
westcory's Avatar
I am hoping I can pick your guys brains on something.....I have a tc-p60st30 and I am having to crank the w/b high Red all the way to the max to try and get proper readings on my i1 display 2. I am using the hcfr software. For the most part all values are coming out well seeing as I am only getting around 0.308 x after 50 ire.
I have all the fluff turned off, mid panel, he,I = graphics as it is. The only setting with proper gamma.
Contrast is measuring aroun 28 and is set at 93, brightness is 51, and color is 48.
Any help would be great as I have been working at this all week.
westcory is offline
post #2 of 7 Old 05-26-2012, 09:12 AM
jdoostil's Avatar
which color temp are you attempting to wb? which pic mode? user menu or service?
ISF certified in 2008
ISF Level II certified in 2010
ISF instructor certified in 2012
ISF International Trainer since 2014
ISFJasonD65@gmail.com
Serving Florida
jdoostil is offline
post #3 of 7 Old 05-26-2012, 03:41 PM - Thread Starter
westcory's Avatar
Using warm 2, using custom and I haven't dove into service menu. I am not familiar with the Panasonic service menu.
westcory is offline
post #4 of 7 Old 05-26-2012, 05:11 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
Forget the readings. How does white actually look? If it is red or pink tinted, then your meter has drifted.
Its very common unfortunately.
fahrenheit is offline
post #5 of 7 Old 05-26-2012, 06:42 PM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 285
You may want to take a look at the first couple of posts in this thread, especially if everything does not look good.
http://www.avsforum.com/avs-vb/showthread.php?t=1411462
Most of the thread is just noise but it does explain why your picture may not look as the readings would suggest .. if that is the case.
Also, if you are local to Philadelphia PA, I would be happy to help you as I have others on the board.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #6 of 7 Old 05-26-2012, 11:56 PM - Thread Starter
westcory's Avatar
I think you guys are correct. Initially I was impressed, however the baseline was just terrible, so anything would have been better.
I will pick up an i1 pro and try to calibrate it using that. I am in Seattle if anyone knows of a good calibrator here.
westcory is offline
post #7 of 7 Old 05-27-2012, 09:00 AM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 285
Please note, you can rent a spectro to do a profile and then use the D2. You do not have to buy another meter, there are options.
Doug
Reply Display Calibration
Panasonic Viera Tc P60st30 60 Inch 1080p 600 Hz 3d Plasma Hdtv
