Which iMac profile should I calibrate from? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-29-2012, 02:30 AM - Thread Starter
sefmiller's Avatar
For watching video on the screen & general use.
Should I calibrate:
iMac
Adobe RGB (1998)
Generic RGB Profile
sRGB IEC61966-2.1
sefmiller is offline
post #2 of 3 Old 05-29-2012, 03:58 AM
Chronoptimist's Avatar
Liked: 532
If your definition of “calibrate” is to select a colour profile for the display, you should use the default iMac one.
If you are using hardware instrumentation, you should use a software package that creates its own ICC profile for the display.
Chronoptimist is offline
post #3 of 3 Old 05-29-2012, 04:46 AM - Thread Starter
sefmiller's Avatar
Yes, I meant the calbration software available in the system preferences.
Reply Display Calibration
