Calibration help for a newbie with Calman v4 DIY and i1 Display Pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 05-30-2012, 12:11 AM - Thread Starter
yenal's Avatar
I've just purchased Calman v4 and i1 Display Pro. My ST50 arrives tomorrow and I am really excited to start my first calibration. Can someone please tell me if I will need to get into the service menu to calibrate the ST50 properly with Calman and i1 Display Pro? Also I see that Calman can control some displays over tcp/ip. Is ST50 one of these displays?
By the way I have tried my colorimeter with ColorHCFR but it did not work for some reason. I was getting a device not connected error even after I copy the EyeOne.dll. Actually even i1 Diagnostics Tool cannot detect the device. But the monitor calibration software in the disc seems to detect the device just fine. Is it possible that the colorimeter is broken?
Yenal
yenal is offline
post #2 of 25 Old 05-30-2012, 03:53 AM
ConnecTEDDD's Avatar
Quoted: 1048 Post(s)
Liked: 1515
Unfortunately ST50 is not supporting any type of DDC from Ethernet or RS-232. You have to do it manually.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3 of 25 Old 05-30-2012, 05:58 AM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
Yenal
If you want to calibrate Cinema mode you will need to access the service menu, otherwise calibratiing custom requires no service menu access. Just fyi you should probably wait about 150 hours or so before calibrating. Your greyscale will most likely change between now and then.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #4 of 25 Old 05-30-2012, 06:10 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
As a new calibrator I'd think he'd want to start using his equipment and learning ASAP. My suggestion is to calibrate now, 20 hours, 30 hours, etc........
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is online now
post #5 of 25 Old 05-30-2012, 07:49 AM
PeterLewis's Avatar
Quoted: 128 Post(s)
Liked: 63
You should wait until 150-200 hrs to start calibration....The panel is to new to keep putting up the menu screen constantly.Many have claimed to get stubborn IR from the TV's Menu screen when new.
Sony OLED XBR-65A1E (In my Future )| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #6 of 25 Old 05-30-2012, 08:54 AM
Quoted: 46 Post(s)
Liked: 61
I've had my VT50 with AVS HD 709 windows for hours with no IR problem.
I started the day I got it.
Mike
wmwilker is offline
post #7 of 25 Old 05-30-2012, 09:03 AM
chunon's Avatar
Liked: 1772
True practice makes perfect I was just really trying to point out the panel will change over the first 100 to 200 hours.
65C6 OLED
post #8 of 25 Old 05-30-2012, 09:04 AM - Thread Starter
yenal's Avatar
We've got some conflicting answers here I really would like to start calibrating right away but I see the point with IR. I did not see any messages about why the i1 does not work with ColorHCFR. I hope the meter is not broken.
Thanks everyone.
yenal is offline
post #9 of 25 Old 05-30-2012, 09:30 AM
djams's Avatar
The Display Pro is not supported in the original version of HCFR. The new HCFR fork supports it, but uses the Argyl CMS drivers, not xrites.
Its strange that diagnostics does not detect the meter but it works with the monitor calibration software. I have no ideas on what is wrong here.
djams is offline
post #10 of 25 Old 05-30-2012, 09:50 AM - Thread Starter
yenal's Avatar
Is it possible that this meter is locked to the i1 profiler software it came with? SpectraCal still did not send me my license key. I will try with Calman to see if it detects the meter. By the way the distance between the meter and the weight on the USB cable is very short. Is that how this meter is set up?
yenal is offline
post #11 of 25 Old 05-30-2012, 09:55 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Calman works in simulated mode until you put in the license key. IT will not allow you to hook up a meter without it.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #12 of 25 Old 05-30-2012, 09:59 AM - Thread Starter
yenal's Avatar
Originally Posted by Michael TLV View Post
Greetings
regards
I know. I already purchased the software. It's just that they did not send me my license key yet.
yenal is offline
post #13 of 25 Old 05-30-2012, 06:17 PM - Thread Starter
yenal's Avatar
Hello guys,
Apparently there is nothing wrong with the meter. It worked just fine with Calman. I have just finished my first calibration. I now realize that I should have gone with at least GT50 because there was not much calibration options with ST50. Can someone please tell me how these numbers look? Also is there a better way to export results than the way I did. I basically printed the workflow screen to a PDF printer.
-Yenal
Post-Cal Capture.pdf 77.873046875k . file
yenal is offline
post #14 of 25 Old 05-30-2012, 08:21 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
The weight can slide along the length of the cable, the weight has a button on it, hold the button while you slide the weight where you need it to be.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #15 of 25 Old 05-30-2012, 08:23 PM - Thread Starter
yenal's Avatar
Jason
I feel stupid now I taped the thing on the TV.
yenal is offline
post #16 of 25 Old 05-30-2012, 08:46 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
No reason to feel like that, we all overlook the obvious from time to time.
Jason
post #17 of 25 Old 05-30-2012, 09:26 PM - Thread Starter
yenal's Avatar
Any comments on my calibration results?
yenal is offline
post #18 of 25 Old 05-30-2012, 09:39 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Looks like your grayscale could be a little tighter. The gamut looks solid.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #19 of 25 Old 05-30-2012, 09:45 PM - Thread Starter
yenal's Avatar
Shall we say I did a decent job for a first time calibrator? I want to calibrate my 55" Sony NX720 now
yenal is offline
post #20 of 25 Old 05-30-2012, 10:05 PM - Thread Starter
yenal's Avatar
By the way I kinda feel like I wasted my money on Calman v4 DIY. It's not that it's a bad software. Actually it's pretty good. But I guess I would have got the same results with ColorHCFR if it worked with my meter.
yenal is offline
post #21 of 25 Old 05-30-2012, 10:11 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
You can get the same results x,y,Y numbers and a pad of paper or an excel spreadsheet. I started with using HCFR, and I did some calibrations with nothing but software that dumped the x,y,Y values from a spyder2.
Once you start trying to do more advanced things CalMAN really does start to shine. Also sometime this summer CalMAN 5 will be out. It's a significant refinement of the product and will be a free upgrade to those who purchased in the last year.
Joel Barsotti
SpectraCal
sotti is offline
post #22 of 25 Old 05-30-2012, 10:16 PM - Thread Starter
yenal's Avatar
I see what you're saying but I am just a hobbyist. I am actually excited to calibrate the NX720 because it has way more calibration options. The ST50 was really limited in calibration options. But the picture quality in ST50 is unbelievable. By the way I still don't understand why i1 diagnostics tool does not work with this meter.
yenal is offline
post #23 of 25 Old 05-30-2012, 10:19 PM - Thread Starter
yenal's Avatar
By the way I just realized that you're the lead developer of Calman. I am also a software developer and I did not mean to disrespect. Since I was so unfamiliar with the calibration process I thought I can save some time by going with a professional software. Actually as a matter of fact it saved me some time because SpectraCal customer support was super helpful.
- Yenal
yenal is offline
post #24 of 25 Old 05-31-2012, 09:47 AM
derekjsmith's Avatar
Liked: 116
Oh yes the S2xyY project in 2005 I remember that. Kind of the start for the hardware support that is in CalMAN 2/3/4 and now 5.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #25 of 25 Old 05-31-2012, 09:49 AM
Liked: 116
- Yenal
Thank you, we do try to provide the best support system for all levels.
Derek
Reply Display Calibration
