ITU-R BT.[IMAGE-UHDTV] - Parameter values for UHDTV systems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-01-2012, 05:04 AM - Thread Starter
703
703's Avatar
Is anyone here a member?
I would be interested to see if the new draft for UHDTV uses the DCI gamut or x.v.Color (still calibrate to Rec.709, but use negative source encodings to get wider gamut).
Founder | BullsEye Calibration | www.bullseyecal.co.nz
703 is offline
post #2 of 4 Old 06-02-2012, 02:17 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
Last I heard (April), it still hadn't been decided which way to go. I'm sure when the standard is selected, it will be WIDELY released.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #3 of 4 Old 06-11-2012, 05:55 AM
dr1394's Avatar
Quoted: 108 Post(s)
Liked: 57
You can download the draft version here:
http://www.itu.int/rec/R-REC-BT.6B18-0-201208-D/en
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
post #4 of 4 Old 06-11-2012, 11:57 AM
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
From looking through quickly, the main points seem to be:
- 4K and 8K resolution (I'm not totally concerned with this)
- A larger color gamut that is far larger than even DCI it appears
- 10-bit or 12-bit per pixel encoding
- 4:4:4, 4:2:2, or 4:2:0 support for Cb and Cr channels
So we still have lossy chroma information, but we should get some nicer gradients with less banding, and far better colors at least once we get a device that can produce any of those. The green listed is just incredibly large, and I really don't know what can produce that.
Of course, I could easily be misreading it, but here are the values:
Red: x 0.708, y 0.292
Green: x 0.170, y 0.797
Blue: x 0.131, 0.046
White remains at the D65 white point.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
Reply Display Calibration
