VT50 Game Mode Calibration via Service Menu? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-02-2012, 06:54 AM - Thread Starter
Tempest261's Avatar
Quoted: 13 Post(s)
Liked: 33
Pro Calibrators:
Is it possible to calibrate the WB of the VT50's "game mode" in the service menu? There isn't a "game mode" picture option in there, but my understanding is that if I calibrate the custom mode's color temperature, that it should have an effect on the game mode WB... is this true? Or is this too difficult of an endeavor to even attempt?
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Tempest261 is offline
post #2 of 6 Old 06-03-2012, 02:59 PM
Hatedsalesman172's Avatar
It is possible with the right programming and know how of the panasonic service menu's, the only down fall to taking this on by yourself is not having the proper programming in which to do so. What I mean by that is if you dont have the light meter and a program such as CalMan showing you realtime readout's you could do more harm than good. My suggestion is to have a pro calibration tech come and do it, because they can adjust it to the best possible settings to make the VT50 shine, and that model from Panasonic has the best interface for calibration of all the model's. Hope that helps
Hatedsalesman172 is offline
post #3 of 6 Old 06-03-2012, 03:28 PM - Thread Starter
Tempest261's Avatar
Quoted: 13 Post(s)
Liked: 33
I do have a meter (i1 Display Pro), and Calman, and ControlCAL. I've already calibrated the set for ISF Day... just haven't ever messed with the service menu before.
post #4 of 6 Old 06-03-2012, 03:33 PM
mmk well I do know that for the panasonic vt50 to be truely calibrated you must do it through the service menu's, Panny is acutally one of very few tv's that calman can control through the service menu without using the remote. So I would say as long as you are using calman and not adj'ing the programming in other service menu's then you should be good to go, just note about an hour and a half of your life will be consumed in making it perfect. Plus dont get frustraighted if you can't get 100% spot on panny's are just dumb like that from time to time
post #5 of 6 Old 06-03-2012, 04:39 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
The service menu and the ISFccc/Custom modes that CalMAN and ControlCAL can adjust are 2 different things.
Yes, Game mode can easily be adjusted in the SM. It has normal 2 point adjustments for R,G,B. Assuming you used Warm2 as the foundation for the ISF Day calibration, you can calibrate the Normal color temp preset in the SM for Game mode and it will not effect your ISF Day calibration.
BTW, there's no gamma adjustment, so your gamma will not be very good.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #6 of 6 Old 06-03-2012, 04:40 PM - Thread Starter
Tempest261's Avatar
Quoted: 13 Post(s)
Liked: 33
Huh? All of the ISF features are in the Custom mode. Even D-Nice has said he'll probably never go into the SM again, at least with Panny's.
I'll ask it again for any pro calibrators (who have actually touched a VT50): My question was related specifically to game mode, and how to calibrate the color temp, if it's at all possible/feasible.
EDIT: just saw ChadB's post- thanks Chad. That's what I needed to hear.
Reply Display Calibration
