Contrast question - test patterns - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-06-2012, 01:06 PM - Thread Starter
ruiz00tx's Avatar
On Spears & Munsil and Disney WOW disk there are 2 different types of Contrast tests. One shows the white test pattern bars going from 231 to 254 and the other shows 4 squares of White, Blue, Red and Green.
Right now I am using these tools on a Samsung E7000.
If I start at full contrast (100) I need to lower the setting to 98 to see all of the white bars on the test pattern.
When I get to the Clipping test, the white and green squares show the concentric boxes fine but the red and blue do not. To see the concentric squares in the red and blue boxes I need to turn down the contrast setting to around 83.
My question is which setting is technically correct, or which of the settings should I be using?
ruiz00tx is offline
post #2 of 4 Old 06-06-2012, 01:19 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
83 is the most correct setting.
When one of the RGB boxes start to blend the different levels, that means you are clipping that channel. Correct calibration means letting each channel run all the way up to 254, the only time to compromise on that is if you have very limited light output on a projector (below maybe 7 or 8 fl) or plasma ( below 25fl).
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 4 Old 06-06-2012, 01:23 PM
PlasmaPZ80U's Avatar
Quoted: 1966 Post(s)
Liked: 560
The S&M patterns are meant to show WTW all the way up to 254, while the Disney WOW patterns are meant to show a tiny bit of WTW, so that 235 appears distinct from higher levels but the high levels might all look alike (relative to one another). How much WTW you want to show (if any) is up to you and keep in mind the more you show, the more contrast ratio you sacrifice for levels 16-235. Technically speaking showing WTW all the way up to 254 is ideal but if you're more concerned with getting the highest contrast ratio from your set, I would follow the Disney WOW patterns instead which only show a little WTW (similar to DVE HD Basics).
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #4 of 4 Old 06-06-2012, 02:19 PM - Thread Starter
ruiz00tx's Avatar
Thanks for the info guys.
ruiz00tx is offline
Reply Display Calibration
