Better to have 2.2 gamma or stable 2.3 gamma on a plasma? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #121 of 135 Old 01-10-2014, 11:26 AM
mjodotcom's Avatar
Quoted: 14 Post(s)
Originally Posted by chunon View Post
I think the key is standard windows, probably not a huge difference in 6.5 vs 10%. I was a believer in the APL windows until this years models they seem to calibrate truer to life using the standard windows in my experience.
The AVSHD disk has about 14% windows - correct? Is that too large or ok yet?
mjodotcom is offline
post #122 of 135 Old 01-11-2014, 08:21 AM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
You can try that I prefer smaller windows myself, either the GCD disk or Mascoir's disc work great.
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #123 of 135 Old 02-25-2014, 08:24 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
So why has ABL been abandoned - do the 2013 Panasonic sets handle it better for medium sized windows such that it's not an issue?
For what it's worth, I found on my ZT60 that the gamma behaved much closer to the target gamma "pre-calibration" using the AVSHD standard windows. The AVSHD APL patterns still gave me runaway responses when looking at 70-100IRE.
I am guessing that's the ultimate judge for which pattern is appropriate?
post #124 of 135 Old 02-26-2014, 04:18 AM
chunon's Avatar
Liked: 2231
I wouldn't say APL patterns have been abandoned there has always been alot of controversy over apl vs standard windows. I still think the smaller window sizes work better and for my ST60 I found the standard windows looker better to me subjectively. Chad is doing my VT60 in about 10 days and he will probably use APL windows.
Sony 75XBR940E
post #125 of 135 Old 02-26-2014, 06:38 AM
mjodotcom's Avatar
Quoted: 14 Post(s)
So if using ABL windows, do you also set the target 100IRE white level with the ABL pattern? Also, does it matter which window size is used if the idea is to keep the effect consistent?
post #126 of 135 Old 02-26-2014, 06:55 AM
chunon's Avatar
Liked: 2231
Assuming you mean APL patterns, ABL is Auto Brightness Limiter. Yes I use the APL pattern to set contrast, window size of 5 to 6.5% is what I have used.
Sony 75XBR940E
post #127 of 135 Old 02-26-2014, 07:06 AM
Quoted: 1704 Post(s)
Liked: 731
chunon,
On your 60s, do you find much of a difference using 10-10.8% standard windows?
I don't on my F8500 but sure do with my VT50 .... a year earlier model.
JimP is offline
post #128 of 135 Old 02-26-2014, 07:59 AM
chunon's Avatar
Liked: 2231
10% windows as opposed to 5% windows ? Yes there is a difference due to abl, if your set doesn't behave that way it is a definite plus
Sony 75XBR940E
post #129 of 135 Old 02-27-2014, 12:48 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
It still has an effect even if using large or small ABL patterns? Considering my larger AVS disk standard windows appear relatively stable across all stim levels but the large ABL patterns do not, I'm a bit confused which I should use to calibrate too...
post #130 of 135 Old 02-27-2014, 02:27 PM
chunon's Avatar
Liked: 2231
What set do you have ? Software ?
Sony 75XBR940E
post #131 of 135 Old 02-27-2014, 10:42 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
Panasonic ZT60 Plasma, CalMAN 5 with the i1display pro meter
post #132 of 135 Old 02-28-2014, 02:07 AM
chunon's Avatar
Liked: 2231
Assuming you don't have a pattern generator ? If not then your choices are limited fir patterns I would go with the 10% apl patterns off the gcd disc I feel the avs patterns are too large
Sony 75XBR940E
post #133 of 135 Old 03-03-2014, 11:26 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
Assuming you don't have a pattern generator ? If not then your choices are limited fir patterns I would go with the 10% apl patterns off the god disc I feel the avs patterns are too large
Unfortunately I do not have a pattern generator. Where can I find the "god" disc? wink.gif
post #134 of 135 Old 03-03-2014, 11:31 PM
realzven's Avatar
Liked: 84
Look here http://www.avsforum.com/t/1406352/gcd-gamut-calibration-disk
ConnecTEDDD likes this.
realzven is offline
post #135 of 135 Old 03-04-2014, 05:52 AM
chunon's Avatar
Liked: 2231
Typo on my part thanks for the correction
Sony 75XBR940E
Reply Display Calibration
