Poblem with i1Display Pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-08-2012, 01:07 PM - Thread Starter
RYMAJ's Avatar
Hi, I need some advice on this.
I bought the i1Display pro, 2 moths ago. Installed the software and made my first calibration with no problem at all.
Yesterday I finally got my EIZO ColorEdge dsiplay , so I wanted to calibrate it, but the problems started.
First the i1Profiler didnt recognize the i1Display . Then after plugin and unplugin the hardware, it did.
At that point I thought the problems were over but not. Everything were just fine until I ran the calibration test. It began ok, but 1 minute later, the test stopped and a messaged appeared "Unkown error" with a yellow exlamation mark and a red question mark.
So I tried to restart the software, then the PC, but then it didnt recognize it again!.
I repeated all the procees again with the same result, it crashed every time the calibration began, and then it didnt recognize the hrdware.
Ive already unistalled and re-installed everything.
I tried to look on the Device manager if something were in conflict with the USB drivers but everything seems to be right. I mean ther are no exclamation marks.
What can I do?
I have a PC W7 64bits
RYMAJ is offline
post #2 of 2 Old 06-09-2012, 01:20 AM
AV-Freak's Avatar
Why do yo want to calibrate your ColorEdge with iProfiler?!
iProfiler does not use the internal LUT of the Eizo CG series.
You have to use the right software - like ColorNavigator, which you get free with your monitor or other software which does use the internal monitor LUT like Basiccolor, ....
AV-Freak is offline
Reply Display Calibration
