Did grayscale with 94, worth 2nd pass with uv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-09-2012, 07:51 AM - Thread Starter
duke32's Avatar
Got my D3 PRO the other day (thanks Tom!) and redid my grayscale from my old D2. It's amazing how far off the D2 was. I used CIE94 and was able to get <1 dE from 20-100. Would I benefit anything with a 2nd pass using uv, or should I just stop?
duke32 is offline
post #2 of 6 Old 06-09-2012, 09:05 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
That should be plenty close.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 6 Old 06-09-2012, 01:00 PM
PlasmaPZ80U's Avatar
Quoted: 2205 Post(s)
Liked: 663
do you mean LUV or UV? I think ChromaPure only does LUV.
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #4 of 6 Old 06-09-2012, 08:06 PM - Thread Starter
duke32's Avatar
Right, LUV. I just figured out that Chromapure lets you can change your dE method on the fly, so I reloaded my session from last night and changed the dE to LUV and it converted everything from 94 to LUV.....sweet!
duke32 is offline
post #5 of 6 Old 06-12-2012, 12:26 AM
TomHuffman's Avatar
Quoted: 753 Post(s)
Liked: 641
This is just a matter of terminology. We allow selection of any one of 4 dE methods: CIELAB, CIELUV, CIE94, or CIEDE2000. CIE94 is the default. However, we don't consider luminance is grayscale measurements. We handle this with gamma. This issue has been discussed on this forum previously. We use the luminance element in dE calculations only for color. So, technically speaking we use uv for grayscale and Luv for color.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #6 of 6 Old 06-12-2012, 12:29 AM
TomHuffman's Avatar
Quoted: 753 Post(s)
Liked: 641
Anything under 2 is pretty much perfect. THX sets 3 or below as a threshold and SMPTE specifies 4 or below. You are good to go.
Tom Huffman
Springfield, MO
Reply Display Calibration
