Calculating % difference in Y readings between a target point gamma value and actual point gamma value - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-12-2012, 11:04 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 565
Like the title suggests, is there an easy way to convert point gamma differences into % changes in Y? For example, if I was targeting 2.2 gamma at 10% gray and the actual value ended being 2.25, what would be the % difference in Y between the two?
Is there a spreadsheet or other simple tool available to make such calculations/comparisons? I asking for both power and BT.1886 formulas.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #2 of 13 Old 06-12-2012, 11:06 PM - Thread Starter
Liked: 565
perhaps something on the lines of this: http://www.chromapure.com/colorscience-gamma.asp
206
post #3 of 13 Old 06-13-2012, 11:22 AM - Thread Starter
Liked: 565
is this correct? Point Gamma Converted Into Luminance Changes.xls 29k .xls file
File Type: xls Point Gamma Converted Into Luminance Changes.xls (29.0 KB, 89 views)
post #4 of 13 Old 06-13-2012, 11:31 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Yes it is.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #5 of 13 Old 06-13-2012, 11:41 AM - Thread Starter
Liked: 565
Originally Posted by sotti View Post
Yes it is.
great, now I can easily calculate the difference between one point gamma value versus another, at each level of stimulus
if I was to introduce black level compensation into the mix, how would I do that?
post #6 of 13 Old 06-13-2012, 12:01 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
I wouldn't worry about that too much, it basically changes the exponent targets for the stimulus, the difference between the exponents are still consistent.
Joel Barsotti
SpectraCal
sotti is offline
post #7 of 13 Old 06-13-2012, 01:25 PM - Thread Starter
Liked: 565
ok, thanks
post #8 of 13 Old 06-13-2012, 07:01 PM - Thread Starter
Liked: 565
what the is smallest % difference in luminance that would be visible? Also, what is the largest % difference in luminance that would be acceptable?
post #9 of 13 Old 06-14-2012, 05:58 AM
Monitorman's Avatar
Liked: 24
Hi PlasmaPZ80U,
I am not positive about the % of error in color luminance that would actually be visible, but the delta error we strive for is below 3%. I would guess that anything above 5% would begin to be visible to a trained eye at least. I can tell you that low luminance is more visibly disturbing to me than luminance levels that are too high, particularly with green. Hope that helps.
Kevin Miller
ISF Technician
Co-Instructor ISF Level I & II Seminars
Display Product Development Consultant
kevin@isftv.com
Co-founder tweaktv.com
Monitorman is offline
post #10 of 13 Old 06-14-2012, 10:00 AM - Thread Starter
Liked: 565
Originally Posted by Monitorman View Post
Hi PlasmaPZ80U,
Sorry, I forgot to clarify. I was referring to gamma differences specifically (represented as % luminance error from target value).
post #11 of 13 Old 06-14-2012, 04:15 PM
TomHuffman's Avatar
Quoted: 696 Post(s)
Liked: 617
The simplest way to answer this is to just convert reference and test xyY colors to Lab, vary the Y value only and then see how much the dE changes. I'd use CIE94 for this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #12 of 13 Old 06-14-2012, 04:34 PM - Thread Starter
Liked: 565
is the first spreadsheet on this page the correct one to do this with?
post #13 of 13 Old 06-14-2012, 09:07 PM
TomHuffman's Avatar
Quoted: 696 Post(s)
Liked: 617
Yes. I just uploaded an edited version that adds custom color calculation.
Tom Huffman
Springfield, MO
Reply Display Calibration
