Comparing sRGB display to REC 709 Broadcast Display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-13-2012, 01:46 AM - Thread Starter
tech_df's Avatar
Assuming calibration is performed with professional level hardware and software and identical data is sent clean to each display, what differences can be seen between two displays, one calibrated to Rec. 709 and the other to sRGB? They share the same primaries, CCT, and luminance level (at least for the purpose of this discussion), but the gamma curve is different. Is it the clipped data range (white point and black point) and gamma curve of Rec. 709 that differentiates the two, and if so what colorimetric ramifications are there as a result? If not, what discrepancies exist between the two?
Mike Lary
Digital Factory
Seoul, Korea
http://digitalfactory.kr/
tech_df is offline
post #2 of 5 Old 06-13-2012, 04:58 AM
Light Illusion's Avatar
Quoted: 324 Post(s)
Liked: 628
The differences for display calibration is just gamma, and the variation is very, very small.
So small as to be irrelevant in the real world to be honest.
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #3 of 5 Old 06-14-2012, 02:25 AM - Thread Starter
tech_df's Avatar
Does it affect grading decisions, though? I've heard that sRGB is more forgiving of saturation adjustments near the end of the range.
Mike Lary
Digital Factory
Seoul, Korea
tech_df is offline
post #4 of 5 Old 06-14-2012, 03:32 AM
Quoted: 324 Post(s)
Liked: 628
That makes no sense at all...
The only variation is as I said - a small (and virtually irrelevant) gamma alteration.
Steve Shaw
LIGHT ILLUSION
post #5 of 5 Old 06-18-2012, 03:14 AM - Thread Starter
tech_df's Avatar
Bump...
Mike Lary
Digital Factory
Seoul, Korea
tech_df is offline
Reply Display Calibration
