Panasonic TC-L42U30: removing 5 light strips on the right - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-13-2012, 03:17 PM - Thread Starter
artm69's Avatar
Hi,
I purchased this TV a few months ago and finally got the opportunity to view HD on it. Looks great but on some programs I get 5 thin, vertical light strips on the right side. They're about 1-inch tall separated by about 1-1/4-inches.
It seems that if I can shift the display horizontally by a pixel or two this should go away.
Menu>picture>aspect adjustments>HD size is 2. Selecting 1 solves the issue but I don't want to settle for a 95% picture.
Can anyone tell me the procedure to do this, if it's possible?
Art
artm69 is offline
Reply Display Calibration
Panasonic Viera Tc L42u30 42 Inch 1080p 120hz Lcd Hdtv
