DIY calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-14-2012, 09:24 PM - Thread Starter
HEELSFINL4's Avatar
Quoted: 47 Post(s)
I have tried my hand at some DIY calibration and learned a ton on forums like these, as well as from watching pro calibrators. I currently have an eye-one display 2 and use HCFR software. Iknow this isn't the most accurate or comprehensive combo, but it is fairly inexpensive. I need to replace my colorimeter since the Eye one is 5 years old. Assuming i want to continue using the HCFR software (which I do because i understand it!), what is my best alternative on a new meter. Would another eye one be my best bet, if i want to keep costs down? Thanks in advance
HEELSFINL4 is offline
post #2 of 4 Old 06-14-2012, 10:31 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
The i1 Display 2, haven't been manufactured in about a year, so "new" ones are already old enough that their accuracy is starting to slip.
It looks like they've updated HCFR recently to support the i1 Display 3 which is a much, much better meter. I haven't used HCFR in a long time and not with the new update for the i1D3, but that would be your best bet without buying new software.
sotti is offline
post #3 of 4 Old 06-15-2012, 08:08 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
yep, D3 works in open source version of HCFR. There are problems with it on plasmas at certain luminance levels, typically 20-30% stimulus. The red reading at these levels is noisy and can jump around several percent.
zoyd is offline
post #4 of 4 Old 06-15-2012, 11:56 AM - Thread Starter
HEELSFINL4's Avatar
Quoted: 47 Post(s)
Thanks for the info. I see it for around $250 which isn't too much more than the one I have now. Does it lay fluch on the screen likr display one does? Also, is the plasmas issue a dealbreaker, because i do have a plasma.
Reply Display Calibration
