Sharp LC-80LE844u calibration issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-16-2012, 06:45 PM - Thread Starter
Warpster's Avatar
I don't really want to get into the service menu but I went to calibrate this TV and the blue is so far out if I select LOW on temperature the average color temp is around 6900 (LowMed 9600), I can get that down (using low) but I'm having difficulty getting the gray scale close enough for my liking so I would prefer to use the 10 point adjustments. Using the 10 point I can get the gray scale great but then the luminosity above 60% starts increasing and the gamma at the upper end is wacked and averaging about 1.9, but all the dE were below 1. My thinking is I need to lower the upper %'s L but I don't seem to have enough range available to do that. Are there other settings (user/CMS) I can make that will affect L at the higher %'s? I'm new to this so any tips would be most appreciated? Anyway I thought if I could get into the service menu I could readjust the preset for the 10 point and the others as well to eliminate the overly aggressive blue....feasible? Thanks...
Also I am using an i1 Display 3 and HCFR (3.0.4.0)
Warpster is offline
post #2 of 2 Old 06-22-2012, 02:12 PM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
johnfull is offline
Reply Display Calibration
Sharp Lc80le844u 80 Inch 3d Led Tv , Sharp Aquos Lc 80le844u 80 Inch Led Hdtv
