Samsung 9 series...calibrating at the factory? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-19-2012, 07:57 AM - Thread Starter
jdoostil's Avatar
If this is true, do they age the panel beforehand? How would they predict the viewing environment? Looks like a K-10 in the video...
http://www.samsung.com/us/sb970/
ISF certified in 2008
ISF Level II certified in 2010
ISF instructor certified in 2012
ISF International Trainer since 2014
ISFJasonD65@gmail.com
Serving Florida
jdoostil is offline
post #2 of 7 Old 06-19-2012, 07:58 AM - Thread Starter
jdoostil's Avatar
click on the "expert tuning" link
Serving Florida
jdoostil is offline
post #3 of 7 Old 06-19-2012, 08:33 AM
Smackrabbit's Avatar
Quoted: 31 Post(s)
Liked: 92
I'm hopefully getting one of these to review once they are shipping, but when they say "Calibrated by hand" it doesn't indicate what the tolerances are for the calibration. Do they just want a dE under 10? A CCT +/- 1000 or is it +/- 100? I'm finishing reviewing an ASUS monitor now that says it has a dE <= 5, but it doesn't specify what dE formula, or what it is measuring to get this. If you are only measuring white, then it's correct. If you're measuring RGB as well, then it's close. If you're doing the Gretag Macbeth color chart, then it isn't correct. Samsung might be dong something as simple as just adjusting the RGB gains or cuts to get the white closer to D65 than it was, but I doubt they're doing a full on calibration of any sort, that just isn't cost effective.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
post #4 of 7 Old 06-19-2012, 07:07 PM
ConnecTEDDD's Avatar
Quoted: 1077 Post(s)
Liked: 1543
It's not Klein, they are using a Konica Minolta CA-210
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #5 of 7 Old 06-20-2012, 03:06 AM
703
703's Avatar
The ASUS 27" claims pre-calibration as well.
http://www.asus.com/Display/LCD_Monitors/PA248Q/
The funny thing with the Samsung is that, Samsung is the master of oversaturation, just look at their Galaxy S2 and S3 phones smile.gif
Founder | BullsEye Calibration | www.bullseyecal.co.nz
703 is offline
post #6 of 7 Old 06-20-2012, 08:28 AM
Quoted: 31 Post(s)
Liked: 92
I was testing the ASUS PA246Q (I got it in before the new one was announced) but it doesn't say how they get their dE of 5.0. That's the thing, is Samsung/ASUS/everyone can say "Calibrated from the factory" but there isn't a standardized way of measuring that. Does that mean all primaries and secondaries, as well as the grayscale, are under 5? Or does that mean that 100% white is under 5? Which formula? Unless these are specified I don't know if they are meeting the standard or not.
I'm just running them through the 24 swatch Gretag Macbeth pattern, and if they are under 5 for an average on that, I'd consider it meeting the standard. If not, then I don't consider it any better or worse than any other display coming to me.
Chris Heinonen
post #7 of 7 Old 06-22-2012, 12:30 AM
703
703's Avatar
The standards body should really define what is considered meeting the standard and what is not. Similar to car saftey ratings. E.g 5 star could be DE < 1 for primary/secondary/greyscale tracking. Otherwise, marketing will just run wild and calm everything is accurate and calibrated.
703 is offline
Reply Display Calibration
