What's the best meter for under 100$ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-20-2012, 11:25 AM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
I'm a newbie to calibration. I have an old crt rear projection by hitachi, i've been trying to find a decent meter used on kijiji but I haven't had any luck. What are the best search terms to use on a site like kijiji (Canadian Craigslist) to find colorimeters?
Until I can find a decent meter i'll be touching up the grayscale by eye (it's that bad smile.gif
Do the gain controls effect shadow detail or is it only the cutoff controls that effect shadow detail and what exactly is the difference between the gain and screen controls located on the crt focus pack. I've also heard that once i've bought a meter i'll have to have it calibrated? is that an expensive or difficult process?
I should also mention i will need a good software program as well, i'm running of a htpc and have avia so far. Thanks in advance smile.gif
Mik James is offline
post #2 of 16 Old 06-20-2012, 12:17 PM
AvidHiker's Avatar
Quoted: 24 Post(s)
Liked: 45
Well until a few weeks ago, you could still buy an i1D2 new for around $100. However, I would never buy one of those used because they can suffer from major drift after a year or two, especially if they haven't been stored in a dry environment. Not sure about other options, but I would be careful buying anything used (unless it's been recaled or profiled) since you don't know how well it was cared for.
AvidHiker is offline
post #3 of 16 Old 06-20-2012, 01:00 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
What is recalibration and profiling, is that something i can do myself?
post #4 of 16 Old 06-20-2012, 02:25 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
None, spend the $100 on a lottery tickets and maybe win $350 so you can get the lest expensive fairly accurate meter, it would be money better spent.
For $200 you can rent an accurate meter and software for 14days.. or you can rent a spectro for $99 without software..
http://store.spectracal.com/i1pro-calibration-rental-kit.html
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 16 Old 06-20-2012, 03:07 PM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
If you're willing to spend a couple hundred on a used i1Pro rev D spectro, you can use it with the free ColorHCFR. It will be be very accurate on all display types and can be paired with a cheap colorimeter for speed and low light sensitivity. As far as using a sub $100 colorimeter alone, that is not worth the time nor the effort as it will only be accurate when paired with a spectro like the one I mentioned.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #6 of 16 Old 06-20-2012, 03:28 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
So your saying that i need 2 things now? What is the difference between a colorimeter and a spectrometer? No i'm not willing to spend a couple hundred bucks, if i can't get a decent used meter for less than 100$ that will do better than my eye then i won't be buying a meter right now.
post #7 of 16 Old 06-20-2012, 04:41 PM
Liked: 560
the best you can do for that money is rent a spectro w/o software (and use free ColorHCFR software instead)
any used sub-$100 colorimeter you can find won't be of any use... just wasted money
post #8 of 16 Old 06-20-2012, 06:29 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
So if i we're to say buy a dirt cheap low end meter i could then calibrate with a rented high end meter?
Will both types of meter do what i want? Cause if both will work then i should just save my pennies for a i1pro right unless there are other companies that make these meters at better prices?
]Even if i don't buy a meter i pretty much have nothing to lose by tweaking this crt to get the grayscale even, i realize i can't do gamma by eye though. So what is the difference between the screen, gain, and cutoff controls? is it only the cutoff control that effects shadow detail?
post #9 of 16 Old 06-20-2012, 08:27 PM
Ericglo's Avatar
Quoted: 1697 Post(s)
Liked: 796
The Spectracal rental comes with software.
You are better off renting a meter from Spectracal for your budget. Your CRT shouldn't need recalibrating that often.
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is offline
post #10 of 16 Old 06-20-2012, 09:53 PM
Liked: 560
The i1Pro rental kit is $200 for 14 days. I assume you're referring to the ColorMunki Rental for $100 for under 30 days? that doesn't come with CalMAN DIY if you don't already have it
post #11 of 16 Old 06-20-2012, 09:55 PM
Liked: 560
if speed and low light sensitivity are not important to you, the spectros can be used alone... if those things do matter, you can buy a cheap colorimeter for under $100 and profile it with the rented spectro to get the accuracy of the spectro with the speed and low light sensitivity of the colorimeter... the profile will remain accurate on the display it was created on as long as the colorimeter doesn't drift (further) from the date the profile was created (by you on your actual display)
post #12 of 16 Old 06-21-2012, 09:15 AM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Alright thanks for your help smile.gif So on to the gain, cutoff and screen controls what is the purpose of each?
post #13 of 16 Old 06-21-2012, 09:21 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Please take a read over this guide it will help give you the basics. It refers to projectors but is applicable for all types of displays.
http://www.curtpalme.com/forum/viewtopic.php?t=10457
Please note this is rather dated from 2008 and meters and hardware has improved but the basics have not changed.
Also lots of data on the the Spectracal site.
http://store.spectracal.com/support/knowledge.html
Doug
post #14 of 16 Old 06-21-2012, 10:18 PM
Ericglo's Avatar
Liked: 796
You are correct. I don't think I ever looked at the Munki rental.
Ericglo is offline
post #15 of 16 Old 06-23-2012, 08:09 PM - Thread Starter
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Thanks for the link smile.gif I'll probably hold off on getting a meter for now but it's good to know what I need to buy. What's a calman DIY?
post #16 of 16 Old 06-23-2012, 09:27 PM
Liked: 560
calibration software for DIY use that goes for $200
another similar package is ChromaPure Standard, which is also $200
Reply Display Calibration
