BT.1886 - a question? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 63 Old 03-02-2014, 07:23 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
The overall soft picture/gamma may work better(more consistent) on this tv as there's nothing I can do about the washed out picture/ gamma at high abl...budget samsung((no 10pt or cms).Whatever a persons preference is.Athough it missing some pop.
Vic12345 is offline
post #62 of 63 Old 03-09-2014, 01:24 PM
denide's Avatar
so after recalibrating my st60 from power 2.2 to 1886 i watched it for a while and that the 1886 resulted in a much more elevated look to low light scenes making shadow detail easier to see than 2.2 (doesn't make sense to me how this is possible). but gives some shots a flatter look. the target calman set for me for 1886 was 2.3. i did a comparison by having custom mode at 2.2 and cinema mode at 1886. i would have thought the 2.3 target would have had the opposite result but i guess thats part of the calculations differences between the two. wondering if anyone thinks this is "normal" or if i made a mistake.
denide is offline
post #63 of 63 Old 03-09-2014, 01:43 PM
ConnecTEDDD's Avatar
Quoted: 1078 Post(s)
Liked: 1546
Hi, since we don't know what gamma each movie has color granded with, it's a good idea to have 2 different calibrated gamma settings to your setup and swap after each movie starts to the setting that look better to your eyes.
I do the same with my eeColor, having 6 different gamma settings stored wink.gif
It's very easy if you use LightSpace since from one 3D-Cube measurement data file you can generate in seconds as many gamma target correction LUT's you like, without re-measuring again for each gamma target.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Reply Display Calibration
