SAMSUNG LED UA32ES6200 - Messed up with AV Calibration like most of us here!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-23-2012, 07:24 AM - Thread Starter
Mohit Sangal's Avatar
Hi I have recently bought a samsung led ua32es6200 3D smart led tv and somehow unknowingly while surfing the service menu i have disturbed the calibration in AV settings..mad.gifmad.gifmad.gifmad.gifmad.gif.
thnx to other posts on avsforum.com, i was able to recalibrate the tv with 8*8 checkboard and regain colors but still the crisp image is missing as the checkboard used was not for this model....
I will be greatful if anyone here can help me out....
thanks in advance for your kind responses......
Mohit Sangal is offline
post #2 of 21 Old 06-23-2012, 07:29 AM - Thread Starter
also i would like to tell you that after using the checkboard for calibration the status was "failure" but still the image was much better then before and right now its bright but blurry.... I can see distortion in the images.... plzz plzzz help!
post #3 of 21 Old 06-23-2012, 08:28 AM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Easiest thing for you to do...will be ..return the TV...get another one.
And please....don't go into the service menu...the controls you need to calibrate are more then likely in the user menu.
RayJr
Rayjr is offline
post #4 of 21 Old 06-23-2012, 01:23 PM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
There aren't different checkerboards for different models - make sure you use one that has a black square in the upper left corner. If you can't figure out how to do the checkerboard calibration then check these values in the SM under ADC/WB->ADC Target. They should be close to values indicated, if not set them there.
2nd_R_L 130
2nd_G_L 130
2nd_B_L 130
2nd_R_H 80
2nd_G_H 80
2nd_B_H 80
zoyd is offline
post #5 of 21 Old 06-23-2012, 02:16 PM - Thread Starter
2nd_R_L 130
2nd_G_L 130
2nd_B_L 130
2nd_R_H 80
2nd_G_H 80
2nd_B_H 80
Thanks Zoyd.... but please help me with the values for 1st _Y_GH too as i think this is primarily important .... 1st _Y_GH value is 375 .... is this fine???
post #6 of 21 Old 06-23-2012, 02:22 PM
zoyd's Avatar
Liked: 1051
zoyd is offline
post #7 of 21 Old 06-23-2012, 02:37 PM - Thread Starter
That's for component input, which input did you mess up? I have no idea what the component values should be.[/quote
by any chance do you have the checkboard pattern for my led tv as I could find only the ones with white square at top left .. mad.gif
post #8 of 21 Old 06-23-2012, 02:46 PM
zoyd's Avatar
Liked: 1051
They are called modified or inverse ANSI contrast patterns. You can find them on this disk in HD format or use the disk from this post, chapter marked 16-255 on DVD.
zoyd is offline
post #9 of 21 Old 06-24-2012, 12:03 AM - Thread Starter
No luck... the ADC calibration is still a "failure"... I played the video with the referred pattern number 16-255 for almost 5-6 times but the status was still the same...
the image is blur and grainy but still viewable ..... I really dont know what's wrong ... i think i have messed it up badly:mad:mad.gifmad.gifmad.gifmad.gifmad.gifmad.gif
post #10 of 21 Old 06-24-2012, 04:41 AM
zoyd's Avatar
Liked: 1051
1. Which input are you using for the dvd?
There should be four calibration menu options in the SM:
AV Calibration
Comp Calibration
PC Calibration
HDMI Calibration
2. Which of those options did you use?
zoyd is offline
post #11 of 21 Old 06-24-2012, 06:09 AM - Thread Starter
The first one... AV CALIBRATION
post #12 of 21 Old 06-24-2012, 06:11 AM - Thread Starter
moreover I am facing another problem... once i turn on my tv's 3D mode and switch it back to 2D the image is all dark green kinds.... then if i just power off the tv and power on, Its perfectly ok.... strange
post #13 of 21 Old 06-24-2012, 06:58 AM
zoyd's Avatar
Liked: 1051
oh I see. So the AV input (cable card/antenna) is the one you have messed up? If that's the case you need to get the checkerboard pattern to that input, I don't know how to do that.
zoyd is offline
post #14 of 21 Old 08-02-2012, 03:18 PM
Shan MB's Avatar
i am also facing same problem with av callibration . please help me...............
Shan MB is offline
post #15 of 21 Old 08-02-2012, 03:19 PM
Shan MB's Avatar
this for UA40ES6200 samsung tv
Shan MB is offline
post #16 of 21 Old 08-02-2012, 03:38 PM
Shan MB's Avatar
Originally Posted by AJC3317 View Post
i know this thread is very old and i'm probably gonna get modded or something for posting this, but i just have to say that i had this problem and this same model of tv and this post completely fixed the problem i moronically caused myself. so matt & wife, if you happen to still come to these forums and see this post, THANK YOU SO MUCH!!!!!!
Tried this settings also no luck
Shan MB is offline
post #17 of 21 Old 08-02-2012, 03:45 PM
Shan MB's Avatar
Originally Posted by Wifey_Sherriff View Post
TO ANYONE WHO IS THINKING ABOUT CALIBRATING (OR WHO HAS SCREWED IT UP ALREADY):
I made the same STUPID, STUPID mistake of going in to the service screen because I simply wanted to check how many hours we've used our TV in the past 2 1/2 years. Well, this was by far, the DUMBEST THING I've ever done with an electronic piece of equipment. I was even forewarned that accessing the SERVICE menu could cause irreparable damage, and I was still cocky enough to believe that I knew what I was doing (even though I am very technologically savvy).
Let me be clear... UNLESS YOU ARE A TRAINED, CERTIFIED, EXPERIENCED TV PROGRAMMER, OR REPAIR TECHNICIAN, DO NOT SCREW AROUND IN THE SERVICE SCREEN!!! Save yourself hours of issues (and potentially a permanently busted TV)!
So what happened, is that I accidentally hit the "CALIBRATE" button (as it is the first option on the SERVICE SCREEN). The remote isn't user friendly when it comes to using the service screen - the buttons you use, don't match up to the "flow" on the TV. The TV started calibrating a frozen image from the show "COPS". I didn't know how to stop it, and didn't understand that it was completely screwing it up, until after it finished calibrating.
Anyway, my wife and I just finished spending over 10 hours working on fixing the TV since last night - and thank goodness she's one hell of a GOOGLER. Even though I found this website last night with info about the fix, it took digging further to help find the correct calibration image to fix the issue.
HERE'S THE STORY:
I have a Samsung LCD LNT-4661F, built in early 2007. Last night, after reading about the checkerboard fix, I gave it a try - NO SUCCESS.
BUT, in the end, a different way of using the checkerboard DID work, so read on (if you've made the same mistake and still need help).
As it turns out, you have to have the checkerboard image the exact same resolution of your TV. Mine was 1920x1080. I used an 8 x 8 Black & White checkerboard image, using my PS3 (using the "VIEW PHOTO" feature).
When using the checkerboard image (or any other calibrating image), MAKE SURE THERE IS NO OTHER "INFO" ON THE SCREEN (such as the little menus that show "next" or "back" or other random information). The image MUST BE completely isolated, with nothing but the full-screen 8x8 B&W checkerboard, with a native resolution equal to your TV.
FOR THOSE OF YOU WHO NEED THE 1920x1080 8x8, I've linked to it from my PHOTOBUCKET account, because I know how frustrating and tough it was to find it!
DOWNLOAD THE 8X8 BLACK & WHITE 1920 x 1080 HERE:
B&W 1920x1080 Calibration Picture
Where I first went wrong (using the checkerboard fix) is that I wasn't using the proper image resolution (and I think it was also associated with two, very fine lines on the left and top of the image that showed on the screen, since I was using my wife's computer with HDMI output). Point is, it wasn't isolated and the resolution wasn't correct.
Once you have confirmed you have the correct image and it is loaded FULL SCREEN somehow (PS2 / PS3 / DVD / COMPUTER, any HDMI input), carefully re-run the CALIBRATION from the service screen. Don't touch any other settings in the service screen, just the HDMI calibration! Give the calibration about 1-2 minutes to run, and then turn the TV off for at least 60 seconds. The calibration that FIXED my TV only took about 30 seconds to run. PREVIOUSLY, when I tried calibrating using different images (THX image from a DVD), and the image with the incorrect resolution, it took 5 or more minutes. If it takes that long, it's likely not calibrating correctly.
Now, I still have an issue with the CONTRAST... When I change the contrast from the main menu up and down, each "value" (between 1-100) GREATLY increases or decreases the contrast. And it "cycles", as in, a setting of 98 looks normal, but if you set it down to 93, it is nearly BLACK. But, when I go down one more to 92 it is back to SUPER bright (too bright), and so-on. It does this over and over again, every 5 or 6 values, from 1-100.
This seems to be the only issue we still have after fixing it. I think it's about 99.9% of where it was before I got completely moronic and screwed with the SERVICE SCREEN...
So, let me say it again... I highly recommend that even the "TECH SAVVY" folks NEVER play with the SERVICE SCREEN unless you absolutely know what you're doing. In fact, unless you are so qualified, that you can actually modify the settings with your eyes closed, I'd say never screw with it. I mean, I consider myself incredibly tech savvy... I build computers, component by component, install and configure massive home audio surround sound systems, can disassemble and reassemble a car, just about everything; but the first and only thing I've run into that I could NOT wrap my mind around was this calibration issue!
Everyone else who's made this same mistake knows how sickening the feeling is, believing that you may have just trashed your $3,000 TV... Trust me - it's not worth playing around with; just don't mess with it!
On another note... Thanks to everyone for their help on these forums. I'd be crying myself to sleep every night had I not come across this forum, which helped me put the pieces together on how to fix it!
-Matt & Wife!
Shan MB is offline
post #18 of 21 Old 08-02-2012, 03:46 PM
Shan MB's Avatar
not working for Samsung ua40es6200
Shan MB is offline
post #19 of 21 Old 08-02-2012, 04:30 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Have you tried the "Factory Reset" option in the service menu?
Dropkick Murphy is offline
post #20 of 21 Old 01-02-2013, 02:43 AM
mchaber's Avatar
hello All.. seem no valuable response since last post..
Could UA40ES6200 model owners post service menu's ADC sections screenshots here, to try to save victims of AV calibration please ?
MANY THANKS !
mchaber is offline
post #21 of 21 Old 06-05-2013, 03:28 AM
Georgialean's Avatar
Samsung UNES6150 user. i was only going to fix the sound for my hdmi/dvi connection to PC. until i read a post that i should open up the SM menu to enable the sound and i accidentally hit the AV calibration and didnt know what to do i unplugged the cord of my tv. Now my tv is messed up. I dont know if would able to watch a local cable channel from it. Ive tried a lot of checkerbox including the 4 box checkerboard nothing seems to work. I dont know if i need to use a different gadget to input the checkerboard. i tried using samsung DVD BD HT. also tried Sony blueray DVD. Please help me i dont know how will i fix it. And this tv was shipped from U.S. to me here in the philippines and i dont know if there are samsung tech service center here. If there are someone with same unit who already fixed this AV calibration Pls post your method and solution here or mail me itll be a great help thanks. jeffmaru@yahoo.com
Georgialean is offline
Reply Display Calibration
