Ipad2 color temperature - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-25-2012, 09:16 PM - Thread Starter
booker21's Avatar
Has anyone measured the ipad2 display?
Everytime I use the iPad while watching tv I feel my tv set is too warm. But I think my eyes are getting used to the iPad, which I believe it's bluer.
Anyway, wondering I'd someone ever measure the ipad2 display.
booker21 is offline
post #2 of 4 Old 06-25-2012, 10:32 PM
Chronoptimist's Avatar
Liked: 543
Found this online:
iPad 2:
iPad 3:
As a mass-produced device, I would expect there to be some variation between displays (especially the iPad 2 where there are multiple sources for the display) but your iPad 2 is probably too blue.
Chronoptimist is offline
post #3 of 4 Old 06-29-2012, 12:09 AM
WiFi-Spy's Avatar
Quoted: 521 Post(s)
Liked: 966
I measured an iPad 2 and iPhone 4S, both had color temps close to 8000K.
I use a jailbreak app called Color Profiles to adjust the color temp on my iPhone 4S closer to D65.
Tyler Pruitt - Technical Liaison - CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #4 of 4 Old 07-01-2012, 06:43 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Originally Posted by Chronoptimist View Post
Found this online:
iPad 2:
iPad 3:
We have an ipad2 and ipad3 at work for development and side by side you can't see any color shift. If blue was that strong on the ipad2 it would be noticeable. Both displays looked very good in the color temp department.
Ronomy is offline
Reply Display Calibration
