Calman & Rear Projection TV Calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-09-2012, 11:54 PM - Thread Starter
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
Hi,
I have Calman 4 connected to an i1 Display Pro trying to calibrate my TV, which is a Sony KDS-R60XBR1 SXRD Rear Projection.
With the i1 D3 disconnected the MODE (TARGET DISPLAY TYPE) - under Settings > Meter Settings - gives me the option for "SXRD Rear Projection".
When the i1 D3 is connected and recognized by Calman, this select menu now changes and the "SXRD Rear Projection" option (and a lot of others) are gone, leaving only 2 rear projection options:
Rear Projector (CRT)
Rear Projector (UHP)
Which one should I select ?
Any other recommendations on settings for rear projection calibration ?
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #2 of 3 Old 07-10-2012, 01:50 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
UHP lamp is the correct choice.
The lighting technology is the only real variable in most display types. CalMAN is trying to move to smaller more concise list of display types. When you see the huge long lists, most of the tables are duplicates entries (IE all rear projection, except CRT rear projection map to the UHP table).
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 3 Old 07-10-2012, 06:23 PM - Thread Starter
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
Joel,
that makes sense.
Thanks !
- M
Reply Display Calibration
