Signal loss 3D HDMI matrix w/HDMI over cat5? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-10-2012, 08:23 AM - Thread Starter
EpicVegas's Avatar
I'm going to be getting a HDMI 4 x 2 matrix with 3D support. My question is I will need to run a hdmi cable over 100ft to the upstairs home theater room. I'm thinking of using a cat5 hdmi extender to prevent signal loss but I dont know if i will loose 3D going through a cat5 extender to my 3d projector. Any ideas if I will loose signal, quality or 3d by doing to?
EpicVegas is offline
post #2 of 3 Old 07-10-2012, 08:55 AM
BobL's Avatar
Liked: 56
At 100' you are probably OK with a cat5/6 balun. Much further and I would look at coax or fibre baluns.
BobL is offline
post #3 of 3 Old 07-10-2012, 10:26 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
HDBaseT extenders work over a single Cat5e/cat6 at up to 300'... Monoprice has a model that uses the HDBaseT technology for ~$200, and includes IR repeating and Ethernet...
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011012&p_id=8123&seq=1&format=2
Jeff
jautor is offline
Reply Display Calibration
Cat5 Rack 1u
