Used Equipment and Software Support - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 07-11-2012, 07:36 PM - Thread Starter
UMD_Terp's Avatar
Please forgive the basic question, but I am starting my research into DIY calibration as I just had a new 65VT50 delivered yesterday. After doing a bit of reading, I think I've decided on starting with an i1 Pro spectrophotometer as my first meter and calman DIY software. From what I understand, I can get the whole package new from Spectracal. What I was wondering was if I were to purchase a used i1 Pro, is there any limitation in the software or meter itself that would make a used meter not work? From what I understand, if I were to buy a used meter, I would need to purchase the calman DIY software plus a spectro add-on license. Is there anything else I am missing?
Also, is there any difference between the various versions of the i1 Pro? For example, Amazon sells a version called the EOBAS Pro... from what I gather, the only difference between the various versions is the software it comes with. Are there any to avoid?
Thanks for any help!
UMD_Terp is offline
post #2 of 20 Old 07-11-2012, 07:43 PM
turbe's Avatar
Liked: 97
If you go used, which is a great option, I'd personally suggest sticking with a Rev D... you can even get the UV Cut version and it's supported in CalMAN as an I1Pro.. You basically have everything else right.
I myself just sold my 4 i1Pro Rev D's to members here on AVS.. all sold for approx. $400 or a little more.
Make sure you get the serial number matched plate.
If you have any questions, feel free to PM me.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #3 of 20 Old 07-11-2012, 07:49 PM - Thread Starter
UMD_Terp's Avatar
Thanks for the quick response! I guess I'll wait around for a deal on a used Rev. D meter. I guess I'll give the TV a few hundred hours of break in and in the meantime keep looking for a meter.
UMD_Terp is offline
post #4 of 20 Old 07-11-2012, 07:52 PM
turbe's Avatar
Liked: 97
Also, the EFI ES1000 is an i1Pro... I believe a AVS member purchased one on eBay for only $75.. if so, that may have been the buy assuming it had the plate and functional.
the earlier Rev's will work but I personally recommend the Rev D.
ControlCAL™
turbe is offline
post #5 of 20 Old 07-11-2012, 08:10 PM
PlasmaPZ80U's Avatar
Quoted: 2239 Post(s)
Liked: 685
what plate are you referring to? what does it do and what is the significance of the serial number matching?
are there any other parts/accessories it should come with? maybe something to use it with in contact mode?
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #6 of 20 Old 07-11-2012, 08:19 PM
turbe's Avatar
Liked: 97
The plate isn't necessarily needed for HT use , but I do suggest you get it (they do come with it from X-Rite)... if you were going to use the meter for spot reading/print work, you will need the matching calibration plate. Resale value will be greater with it.
Here is a pic showing the common accessories
652450
With Ambient light head fitted
296
ControlCAL™
turbe is offline
post #7 of 20 Old 07-11-2012, 11:19 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
The ambient head is required for measuring from a projector and the hanger is really nice to have for flat screens.
You need the base plate to calibrate for measuring reflectance (think paint chips) data.
Both the ambient head and base plater are serialized and should match the meter for best accuracy.
sotti is offline
post #8 of 20 Old 07-12-2012, 09:25 AM
Liked: 685
652450
296
Is the ambient head the thing in the little black box in the top picture? or is that something else?
post #9 of 20 Old 07-12-2012, 10:16 AM
airscapes's Avatar
Quoted: 381 Post(s)
Liked: 304
Yes, the ambient defuser is the black cap with the white dot. Lives in the little black box or just keep it on the meter with the cover over if you are no the type to loss parts.. just keeps the optics clean and protected but could get lost unlike the C6/D3..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #10 of 20 Old 07-12-2012, 10:45 AM
Jeff J's Avatar
Wow, really wish I would have read this before picking up an used i1 pro on ebay for FP and plasma calibration. I just received it, ran diagnostics (ok) and did a little testing on my computer monitor to make sure it was working.
I DON’T think that this ambient head was included…this is the first time I’ve read about this mad.gif
I quick search on the xrite site shows no accessories sold alone – anyone knows if there is any way to procure a ambient light head or am I SOL for projector calibration?
Jeff J is offline
post #11 of 20 Old 07-12-2012, 11:16 AM
Chad B's Avatar
Quoted: 555 Post(s)
Liked: 1318
You don't need the ambient light head to calibrate a projector projecting onto a screen. I used the i1Pro as my main meter for years and never put the ambient head on, and I do many FPs. You only need it if you want to calibrate a PJ facing the PJ lens instead of the screen.
You need the base (with matching serial #) if you ever want to send the meter back to Xrite for a factory recertification, though Spectracal can now provide recert services (they couldn't the bulk of the time that I used the i1Pro), and I don't think they need it.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #12 of 20 Old 07-12-2012, 12:16 PM
Jeff J's Avatar
Thank you, Sir. I feel much better now.
Jeff J is offline
post #13 of 20 Old 07-12-2012, 12:47 PM
Liked: 685
thanks
post #14 of 20 Old 07-12-2012, 01:22 PM
turbe's Avatar
Liked: 97
Agreed, no use even for FP, IMO offscreen is the way to go.. you will need it if you want to do the offset shooting facing the lens..
Where I used the ambient light head, it was for getting the spectral data of a light source, for another project of mine.. mainly some LEDS, w/Argyllcms.
You would use the plate for spot reading recal but don't need it for HT.. I suggest you do make sure you receive it unless you pay <$100 for an i1Pro.
ControlCAL™
turbe is offline
post #15 of 20 Old 07-12-2012, 01:26 PM
turbe's Avatar
Liked: 97
don't worry about it for monitor / display calibration, assuming you got your i1Pro for a great price.. as I said, I had no problem selling 4 i1Pros with the accessories pictured for approx. $400, a very fair price for known history and Rev D's..
ControlCAL™
turbe is offline
post #16 of 20 Old 07-12-2012, 01:42 PM
Liked: 685
Are used ColorMunki Spectros also in the market currently? I noticed SpectraCal has stopped carrying new ones recently. I eventually want to get a used spectro and would like to get a real good deal on it, considering that I'd need to spend an extra $150 on the spectro add-on license key for use with CalMAN. I don't need one just yet since I have a good profile on my C6 for my primary display. I'll be likely getting one when my C6 needs re-calibration (since the spectro can be used to create a profile negating the need for re-calibration, which isn't cheap at $175).
post #17 of 20 Old 07-12-2012, 01:55 PM
turbe's Avatar
Liked: 97
Yes, I have a ColorMunki Photo Spectro (full retail package including never used X-Rite's software), black one.. I will be posting it (there were a couple already interested...
ControlCAL™
turbe is offline
post #18 of 20 Old 07-12-2012, 02:52 PM
DaGamePimp's Avatar
Quoted: 425 Post(s)
Liked: 469
I think the matched base plate is required for running the i1Diagnostics tool however.
Realisticly it has also been stated that other than a dropped (internally damaged) i1Pro nobody appears to have seen one that was actually out of specification regardles of revision.
The various revisions were released within about a year of eachother so simply getting a revision D does not insure anything other than slighty faster reads versus a revision A (B-D are about the same).
The revision D was only released for materials compliance reasons, from a function aspect all revisions are the same other than some read speed tweeks.
With that said it is suggested to get one with a more recent validation certificate from X-rite if you can, just as added assurance of accuracy.
I have talked directly with X-rite on this a couple of times.
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro / Xbox One S / WiiU / PS3 / 360 / Wii / 1080TI game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #19 of 20 Old 07-12-2012, 05:28 PM - Thread Starter
UMD_Terp's Avatar
Thanks for all the advice and pictures guys... immensely helpful.
From my reading it seems that the only drawback to the i1 Pro seems to be low-light readings < 20% stimulus... how much of a hinderance is this going to be in calibrating the VT50? From some reading it seems that people have gotten even the i1 Pro to work with longer read times... either way, I'd rather not have to buy a second meter to get the low end calibrated if I don't have to...
UMD_Terp is offline
post #20 of 20 Old 04-28-2013, 01:11 AM
Gunnar's Avatar
Quoted: 13 Post(s)
Would a Calman Enhanced Spyder3 and a I1Pro be a usable combo? I already have the Spyder and Calman V3.7, and want to upgrade to V5 Enthusiast to take advantage of autocal with my Radiance XD. Would any version of the I1Pro work with Calman?
Gunnar is offline
Reply Display Calibration
