What pattern for what display type - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 07-13-2012, 06:08 AM - Thread Starter
visca blaugrana's Avatar
Hello,
I have for some time been wondering what pattern should be used for what display? I appreciate that this is likely to be a subject full of religion and prefences but here goes as far as I have been able to understand
Plasma: 10% windows 22%apl
LCD: Fields
LED: Fields
DLP fvp: large 22APL
LED fvp:???
SXRD fvp: large 22APL
RPTV: large 22APL
Others I'm missing?
Sent from my iPad using Tapatalk HD
visca blaugrana is offline
post #2 of 25 Old 07-13-2012, 07:18 AM
Chad B's Avatar
Quoted: 551 Post(s)
Liked: 1317
With some LED sets (and LCD sets can follow the same guidelines) using window patterns gives dramatically lower Y readings than using fields, and the fields result is more consistent with the subjective brightness of the image. It's because of the dimming on some LED sets- when only a small area of the screen is lit, they dim the LEDs.
For that reason I would not recommend regular windows for them. I use full field on all LED/LCDs, though I imagine large APL windows might be OK also.
Also, some DLP and SXRDs have a dynamic iris. On the Mits DLP RPTVs sometimes it cannot be defeated. It is best to use large APL patterns on them.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is online now
post #3 of 25 Old 07-13-2012, 07:58 AM - Thread Starter
Thanks for the reply, I will update the first post as we go along.
Regarding projectors and large apl patterns, I assume that is to avoid contamination of the readings. Are we looking at 25% windows or even larger?
post #4 of 25 Old 07-13-2012, 08:11 AM
Chad B's Avatar
Quoted: 551 Post(s)
Liked: 1317
Sorry for the confusion... I meant large as opposed to the small APL patterns on the AVS 709 disc. The reason is the small ones can cause problems with meter aiming in some situations, and I'm not sure if there is enough picture area to avoid LED dimming and/or iris closing.
post #5 of 25 Old 07-13-2012, 08:49 AM - Thread Starter
im not sure we are misunderstanding each other at all, I think we are bot taking about window size, the reason I ask is because I want to create the patterns for the GCD disk, would 35% windows with a fixed 22%fixed APL be suitable?
and yes by contamination of the readings i was referring to fov.
post #6 of 25 Old 07-13-2012, 10:14 AM
ndaa75's Avatar
For plasmas i stick to windows of approx 10-15% panel area size. Apl's just cause the ABL to kick in, checked this with the AVS disc. Ftl with windows approx 45, with APL's 42.
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #7 of 25 Old 07-13-2012, 12:03 PM - Thread Starter
But does using windows not causes problems at 10-40%
post #8 of 25 Old 07-13-2012, 12:53 PM
Chad B's Avatar
Quoted: 551 Post(s)
Liked: 1317
For plasmas you need to use windows. The question is what size (and type- APL or regular) windows is best. For regular windows, personally I like very small to small.
post #9 of 25 Old 07-13-2012, 01:04 PM - Thread Starter
Yes okay, what I meant was does regular windows not cause problem in the range 10-40%
post #10 of 25 Old 07-13-2012, 01:09 PM
PlasmaPZ80U's Avatar
Quoted: 2230 Post(s)
Liked: 682
What size (in % of total screen area) do you use?
I think the AVS disc uses 15% windows.
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #11 of 25 Old 07-13-2012, 01:36 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
THX uses for plasmas 12%
anta1974 is offline
post #12 of 25 Old 07-13-2012, 01:53 PM
Liked: 682
do you mean the THX Calibrator's Disc?
post #13 of 25 Old 07-13-2012, 02:14 PM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
No, organization
anta1974 is offline
post #14 of 25 Old 07-13-2012, 02:32 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
Tom Huffman and I are recommending ~10% area windows on a constant 20-25% average video level image for plasma calibration. These patterns are now available on the GCD disk.
zoyd is offline
post #15 of 25 Old 07-13-2012, 04:04 PM
ConnecTEDDD's Avatar
Quoted: 1559 Post(s)
Liked: 1999
THX Calibration Disk has 5% Square Window Patterns for Grayscale.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #16 of 25 Old 07-14-2012, 01:14 AM
Chronoptimist's Avatar
Liked: 543
Power-limited displays; CRT, Plasma, OLED: Square 1% Area patterns. (alternatively, 22% constant APL patterns though this would not be my choice)
Non-limited display types; LCD, DLP, SXRD: Full field patterns.
Chronoptimist is offline
post #17 of 25 Old 07-14-2012, 03:28 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
1% windows APL or 1% windows ?
LED = OLED ?
or LED=LCD ?
anta1974 is offline
post #18 of 25 Old 07-14-2012, 08:33 AM
Liked: 682
LED = OLED ?
or LED=LCD ?
LED is a kind of LCD (aka LED-LCD) but OLED is not
post #19 of 25 Old 07-15-2012, 01:34 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
New Spears&Munsil disk 8% patterns
anta1974 is offline
post #20 of 25 Old 07-15-2012, 09:09 AM
Liked: 682
when is it coming out?
post #21 of 25 Old 07-15-2012, 09:41 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
this summer
anta1974 is offline
post #22 of 25 Old 07-16-2012, 01:13 AM
realzven's Avatar
Liked: 84
this summer
realzven is offline
post #23 of 25 Old 07-16-2012, 02:09 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
anta1974 is offline
post #24 of 25 Old 07-16-2012, 05:02 AM
realzven's Avatar
Liked: 84
realzven is offline
post #25 of 25 Old 07-17-2012, 11:29 AM - Thread Starter
So this turned out as expected some facts and some religion.
My interest right now is mainly front view projectors .
For this I have been recommended both fields, windows and a larger window with APL. I was wondering if anyone have a set of mesusrements using different patterns?
Reply Display Calibration
