How to save daylight and night settings for Samsung ES series tv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-16-2012, 11:42 PM - Thread Starter
AV-Freak's Avatar
Last weekend I calibrated a Samsung LED tv of a friend.
Worked without a problem. But how can you save the found daylight and night settings?
Usually (LG, Panasonic, ..) you have two profiles where you can store them and switch between them.
But how is this done with Samsung tvs?
AV-Freak is offline
post #2 of 8 Old 07-17-2012, 07:19 AM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
There are CAL-DAY and CAL-NIGHT modes that can be activated in the service menu. In the SM, you select Expert and then turn the N/D ADJUST item ON. There is also a FIX option that locks the settings (OFF, ON, and FIX being the three choices for this item) and the SOURCE item lets you either use separate settings for each source (CURRENT) or the same settings for everything (ALL). Be careful in the SM and only use the up and down arrow buttons on the TV remote to scroll down to the Expert section of the SM and then press enter to access that menu. Then select the item you want to adjust by highlighting it and pressing enter and then the right arrow or left arrow buttons can be used to change the value of the item. You can press the menu button to go back a menu and the power button to exit the SM.
Since the left/right arrow buttons change values in the SM, don't trying using them to navigate through the menus (many have bricked their sets this way).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #3 of 8 Old 07-17-2012, 07:46 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
These cal day and night modes are buggy. I just did a UN- ES7100 the other day and couldn't use them because the 10 pt controls were global between the day and night, and that causes problems.
Might be possible to use Cal Day and then Movie for night, since movie's 10 pt controls weren't tied in with the cal modes. However, I didn't end up doing that myself because after discussing it with my customer he decided he just wanted one mode instead of day and night modes, so I just did Movie.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #4 of 8 Old 07-17-2012, 07:49 AM
Liked: 716
do all current Samsungs have such issues or only certain models/samples?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #5 of 8 Old 07-17-2012, 08:40 AM - Thread Starter
AV-Freak's Avatar
Thanks for this great informations.
I will give it this weekend a try.
Hm, I just had a call with my friend. In the service menu the entry Expert is greyed out and not selectable ...
AV-Freak is offline
post #6 of 8 Old 07-17-2012, 09:51 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 41 Post(s)
Liked: 144
Greetings
It's been buggy for more than a few generations now. Don't even bother trying to lock those night and day modes since the TV has a way of resetting itself when you leave the SM. Lock those day night modes into the default positions is what happens with no way to change it.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #7 of 8 Old 08-01-2012, 11:30 PM
Eicar's Avatar
Hi,
I wondering about how to access the expert menu as well. I got the UE46ES6300.
I can live with shared 10p settings between night and day really.
Right now I'm tired of adjusting the backlight from 9 to 16 based on the lighting...
Eicar is offline
post #8 of 8 Old 08-02-2012, 12:13 AM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I had a samsung d630 and the night setting would not hold and go back to day setting all the time which was too bright for night viewing.I got a bit of a headache from the brightness.
Vic12345 is offline
Reply Display Calibration
